Messed up bolt extraction..... what are my options??
When trying to disconnect an AX-15 from a 4.0, I stripped one of the E-12 bolts on the upper mounting hole. My bolt extractor kit failed to work. I tried using a Dremel to cut off the head and then drill it out, but now I got a bit stuck in the hole and I would like to not damage the bell housing when trying to take it apart. Any ideas on what to do? Are there any specialized drill bits that could help?
do you own a quality 5-way tool?  if not, you should go get one.  one of the best tools ever (just don't get a cheap one)  I would grind that area flat again (trying to eliminate any burrs you've caused that would hurt the process) and use the 5way as a chisel starting with the far side and work my way around.  meaning you're probably going to need to pry them apart, starting with the thinnest tool, the 5way.
you need to make sure that you've gotten all the other bolts, including the inspection cover ones, or this is an exercise in futility. :(
I'll go pick one up next time I'm by home depot
it's in the painting section :L:  I wouldn't bother with the more complicated 9-in-1s or whatever silly number they are up to.  you just want a strong flat stiff chisel/prybar/scraper/etc that you can hammer on without fear of it breaking apart in your hand.  this one is 15 bucks and is one of my favorite tools.
Before you go to using a pry bar or hammer ensure you got all the bolts on the engine plate and engine, some face forward and are easy to miss.
Try grinding the bolt head flat that is stripped out to ensure it isn’t holding things up anymore, then it should just act as a 3rd dowel pin and require extra prying at the top of the trans. once you get it off you should just be able to get the leftover stud off with vice grips and some encouraging words.
On 8/8/2023 at 8:40 AM, pizzaman09 said:
One could also try welding a nut to the stub of the damaged bolt.  The heat should help break free the threads and the nut gives you a great place to stick a wrench on.
I considered suggesting this, I’d just be worried about melting the aluminum
