Gray MJ interior + other MJ only parts (Atl, GA)
Warren99
I bought a 87 Comanche Chief and parted it out, swapping its interior into my 89 Base model. I have everything from my 89 Base models interior + some other Comanche parts that I don’t need. I have no clue what a fair price is for pretty much any of this, but I know I should probably give a few things some prices, so if I’m way too expensive on something you want let me know and I’ll come down(I ain’t looking to make a lot of money, just need to throw stuff away and don’t want to junk a lot of rare stuff).
Not all, but some stuff might be thrown away if not sold soon, but only the XJ parts like the seats or the door cards
$70(Door cards gone)- All of the gray interior stuff- things that are missing include: one of the speaker grilles on the B-pillar panel, the carpet backing panel, any sort of vinyl or carpet for the floor, the floor brackets on the bottom of the bench seat, the dash itself, and that’s all I can think of atm
Vinyl bench seat without floor brackets included, driver side is torn up.
Bench center console also included. Note that this does not include the floor mounting plate underneath it, or the boot as I am using both of those atm. Also note that the center console has a slight bow. I'll take pics if interested
784E28C3-AE39-4074-9BFC-B7A7795C9F5B.jpeg.cd7c91fe65420824b0583258d962177c.jpegC8383CA6-B39D-483D-B52F-71DD999160A2.jpeg.47007e6b856ec2dbd19205f0fdcefe58.jpeg
$40-NOT OEM 4 piece rear window, does include OEM gasket however. C44E301B-976F-4256-9A0B-554AC185CBDA.jpeg.9a8afee29cba03d20c4ad74b2c4a967a.jpeg
$20-(would likely just include with main interior panels) lower air vent heater duct, for bench seat layout93E4C241-EFB4-4AD7-87C6-C55EF26AB41D.jpeg.5b9c7870c06596d4e1d9c705dd981fdf.jpeg
$150(Wheel gone)- 1989 Base model MANUAL steering column. The wheel is from some random XJ, I still have the original. Turn signal does not return after left turns. Price is not very firm.95F6EF45-E694-42F6-85E2-58B4A9473B87.jpeg.71f33f491f2c3dc3e1912e7f2846d37b.jpeg
$60(SOLD)- Full gauge cluster(cable speedo)C8BB4C7C-9F84-4B30-8896-1A838F97C126.jpeg.5010a7a58f47034e24d577bd836bbda6.jpeg
Free(SOLD)- 4 door Cherokee buckets without floor  bracketsBBE08ADB-9D5E-4F27-BE22-90C14285AFD0.jpeg.028c74dfe42d41ced2abfaa2e3bff23e.jpeg
$100(SOLD)-Fuel pump and sending unit assembly 28955CFF-49EA-4F26-AB19-842AFC3DD5E8.jpeg.ad74598693e03b3659e2140bcfeac4d8.jpeg
$150(SOLD)- Headliner(it was black, but the fabric is pretty much shot, the rest is fine tho and could be reupholstered)F1CD1D7F-0269-4FE7-A0FD-AFFD3730014E.jpeg.5fabc67282232388f83a92691b851387.jpeg
^^^$30(SOLD)- rubber belt trim. Not sure how rare this is but it’s missing I think 2 segments, but if my memory serves me correctly, they were both locations identical with an XJ, like the front fenders for example.
$25- Factory Donut spare: this could be the same as on XJs for all I know and be worth nothingB88046FF-CA95-44CB-A218-82C41F0A93CE.jpeg.d87505f006cc627acb9955308450dfcd.jpeg
$150- Parking brake assembly: includes the release lever140A7088-518A-4388-82A9-1B5630F68266.jpeg.6d21ee175cad2b7683ae8e163436a652.jpeg752D6184-7F4B-42EB-8C6B-BCADAF56C14F.jpeg.998a51a0ef424559b9655db4a548e754.jpeg
$20- Rain gutters, not rusted out but repainted at some point 204917A9-B35C-41A7-BD9F-47BE0D119396.jpeg.5413b76e275bdaf70bf55fe02897aa37.jpeg
$40(SOLD)- ROL fog lights7330DEF8-ACC2-47B0-B2D2-C3F5283C58A4.jpeg.62b782b0354b74f75add00334a695ab2.jpeg
$40- OEM heater core: I’ve heard some folks saying they wanted these. This one was taken out because I was pulling the dash and figured I’d replace it then. Nothing wrong with it. 170k miles on the odometer E40F7802-6A2E-4F45-BD9D-D31F562F0A7A.jpeg.5af934870ea5d6e31538e3780f732801.jpeg
$50- Rear brake proportioning valve: no idea if it works, just took it off the parts truck. It had a d44 so the diff cover plate and rod might be different from a d35, not sure tho.1E11D9FD-7853-4CB7-AD5B-E33A5B218AF6.jpeg.085c1475089e6edc403ef5a2932f8eab.jpeg
$25-(SOLD) Cab vents trim2AA19ED8-1FE2-4952-A115-D913EDA5237B.jpeg.db25bf8c9329e4fdf42fa0363ec0063a.jpeg
$50- Spare tire winch assembly0A93977A-655A-4F67-B8EB-1841BE02B353.jpeg.c4f9ab178bdf09b01ab2d60839d31f97.jpeg
$25- the sound deadening that comes under the carpet + the padded insulation that goes against the slope to the firewallF0E17821-5142-4750-AFB4-C4FD6AECED5C.jpeg.9c14379520c58424ce50f0074bb45d56.jpeg
$25- shif boot and 4wd shifter assembly from a 92 YJ2F890BE1-614B-446B-ABB3-DD75C9409B5D.jpeg.581aaa8f5b8fab3411fd6c1c77e6a421.jpeg
$15- Rear speakers + harness(no pic)
$40- tail light wiring harness(no pic)
30 minutes ago, SoCalJeepComanche said:
Yea mines no where near that😂, but I'm sure it’s worth more than $20 now. Keep in mind mines from a base model, and was black. That’s not the original steering wheel but I still have it and should include it. I’ll change the price to $150 but it ain’t firm.
$70- All of the gray interior stuff- things that are missing include: one of the speaker grilles on the B-pillar panel, the carpet backing panel, any sort of vinyl or carpet for the floor, the floor brackets on the bottom of the bench seat, the dash itself, and that’s all I can think of atm
$150- 1989 Base model MANUAL steering column. The wheel is from some random XJ, I still have the original. Turn signal does not return after left turns. Price is not very firm.95F6EF45-E694-42F6-85E2-58B4A9473B87.jpeg.71f33f491f2c3dc3e1912e7f2846d37b.jpeg
$60- Full gauge cluster(cable speedo)C8BB4C7C-9F84-4B30-8896-1A838F97C126.jpeg.5010a7a58f47034e24d577bd836bbda6.jpeg
Free- 4 door Cherokee buckets without floor  bracketsBBE08ADB-9D5E-4F27-BE22-90C14285AFD0.jpeg.028c74dfe42d41ced2abfaa2e3bff23e.jpeg
$100-Fuel pump and sending unit assembly 28955CFF-49EA-4F26-AB19-842AFC3DD5E8.jpeg.ad74598693e03b3659e2140bcfeac4d8.jpeg
$150- Headliner(it was black, but the fabric is pretty much shot, the rest is fine tho and could be reupholstered)F1CD1D7F-0269-4FE7-A0FD-AFFD3730014E.jpeg.5fabc67282232388f83a92691b851387.jpeg
^^^$30- rubber belt trim. Not sure how rare this is but it’s missing I think 2 segments, but if my memory serves me correctly, they were both locations identical with an XJ, like the front fenders for example.
$40- ROL fog lights7330DEF8-ACC2-47B0-B2D2-C3F5283C58A4.jpeg.62b782b0354b74f75add00334a695ab2.jpeg
$25- Cab vents trim2AA19ED8-1FE2-4952-A115-D913EDA5237B.jpeg.db25bf8c9329e4fdf42fa0363ec0063a.jpeg
061D5FE8-9AB1-4360-A151-45312599CA73.jpegi'll take the parking brake assembly if you lower the price, i was asked $60 a few i'll take the parking brake assembly if you lower the price, i was asked $60 a few months back ...... and forgot to get back to him... i'm in Los Angeles.
I'll have to look into how much they are worth. I would assume a decent amount given they are not only Comanche specific, but also a pretty important part. Not to mention, LA would be very expensive shipping.
I could sure use the seat covers and foam. Not all that interested in the associated framework as if they are from a Cherokee they probably don't fold.  A bit far away from me to grab though.
  • 3 weeks later...
Located 30 minutes south of ATL. I'd rather keep the interior bits sold as one but I'd probably let a A-pillar go since anyone could find that on an XJ. I don't have a center console lid, but I do have the MJ floor console. It's a little bowed. I'll post pics if you are interested, that's like the one thing I forgot to post
  • 4 weeks later...
Archived
