JeepcoMJ Posted November 27, 2022 Posted November 27, 2022 Well, life hits how it hits, when it hits. Some of you may remember my old white one pictured below Ā Itās been a long time since Iāve been in the MJ world. Ā this 86 fell in my lap. Ā Close to rust free. Ā 2.5/4speed manual with d35 and 3.55ās. Ā Carpet instead of rubber mat. Ā A/c, cruise, radio, clock, cigarette lighter delete. Ā This will be a supercharged Buick 3800 built: 03kj 8.25 rear w/ 3.73 and discs 98zj 30 front with 3.73 3.5ā OME on all corners 93 Dakota bellhousing 99xj ax15 nv242 cable shift linkage 96 xj a/c core, electric 134 a/c system
Pete M Posted November 27, 2022 Posted November 27, 2022 super looking forward to this build. Ā Ā (side note, we've been having random issues with upside down photos but it has to do with how orientation code is saved in different systems and thus beyond our software.Ā I've found that if I alter the pic at all in my laptop and save, it'll load properly if you're using a phone it's more complicated than i can fix them for you as needed.)Ā
neohic Posted November 27, 2022 Posted November 27, 2022 Looking forward to this. Good to see you back!
JeepcoMJ Posted November 27, 2022 Author Posted November 27, 2022 1 hour ago, neohic said: Looking forward to this. Good to see you back! Thanks! Ā Good to be back! Ā this build will be a total instructional build as well. Ā All part numbers and measurements/dimensions if any fab work will be included
JeepcoMJ Posted December 4, 2022 Author Posted December 4, 2022 She cleans up well. Ā Bunch of parts ordered from key parts. Ā this one will be a supercharged series 3 Buick 3800 from a Grand Prix gtp. Ā I didnāt know about key parts until 2 weeks ago. Ā the original will be back on the road because the parts are available. Ā This will be a side by side build.
fiatslug87 Posted December 4, 2022 Posted December 4, 2022 What are those two holes(?) in the bed front for?
JeepcoMJ Posted December 4, 2022 Author Posted December 4, 2022 6 hours ago, fiatslug87 said: What are those two holes(?) in the bed front for? Factory drain plugs? Ā š¤·š»āāļø. They were there on every 86 Iāve ever owned. Ā Maybe on all MJās
Pete M Posted December 5, 2022 Posted December 5, 2022 3 of my longbeds on hand have them (2 are known 86s).Ā 2 don't (one is for sure an 88).Ā none of the shorties have them.
Minuit Posted December 5, 2022 Posted December 5, 2022 Might be one of those weird 86 only things. I've never even seen those before, but I wouldn't even have been looking.
scguy Posted December 5, 2022 Posted December 5, 2022 Very interesting. I'm a big 3800 fan. They're far more efficient than they have any business being.Ā Ā What trans and how are you running the intake plumbing with the TB on the back?
JeepcoMJ Posted December 7, 2022 Author Posted December 7, 2022 On 12/5/2022 at 6:23 AM, scguy said: Very interesting. I'm a big 3800 fan. They're far more efficient than they have any business being.Ā Ā What trans and how are you running the intake plumbing with the TB on the back? ax15 with a 2.4/ax15 mid 90ās Dakota bell. Ā Another step will be to determine what part number starter will be needed or what starter gear to install on the appropriate bellhousing mounted starter. Ā Because the Dakota, Comanche, etc. 60 degree bell has starter on passenger side, bell mounted, and the 3800 has it on driverās side, engine block mountedā¦and I donāt want to modify the bell. Ā as far as intake, weāre not there yet. Ā Iād imagine that I will need to find 1 of 2 available Eaton M90ās with a 180 degree intake elbow, or modify/manufacture one to bolt on to the standard equipment.
