vanquishings Posted October 7, 2022 Author Share Posted October 7, 2022 5 hours ago, Pete M said: very weird. have you asked C+M about it? maybe this is a known issue? Have an email out to em, now. 20 minutes ago, howeitsdone said: Make sure to measure your yoke on each shaft to verify they sent the correct stub shaft. Regardless, that Spicer U-Joint is correct for the application. I feel like I remember having to install in my inner shaft first. Could have been just me, but there was a method to the madness. The joint doesn't install head-on like you have in the photo. It's more diagonal and off to the side. A very tight fit. I remember it took me a while to find the best way when I originally did mine. Notice how the yoke gets thinner as you get closer to the shaft itself. I actually initially installed the u joint on the inner first, before realizing it wouldn't fit. Turns out I can't return it once it's been installed. I figured there was a method to the madness. I've been playing with em for a while now. The original goes in fairly easily, but I can't even get close with these. I can't help but wonder if it's the wrong stub, but the box is right. So I'm really stumped. I suppose we'll see what C&M says, if nothing else, I can just try another from ebay. Link to comment Share on other sites More sharing options...
zomeizter Posted October 9, 2022 Share Posted October 9, 2022 I'm late to the party but if large tires are in your MJ's future, go with a 'moly shafts kit and be done...price is high though. Link to comment Share on other sites More sharing options...
vanquishings Posted October 11, 2022 Author Share Posted October 11, 2022 C&M got back to me. Assured me that it should work. But I just can't be bothered to spend more than 30 minutes trying to convince u joints to fit. I hope if you guys try in the future, your luck is better than mine. Found a cleaner used unit, we'll see if my brain still tries to fit the square peg in the round hole. Link to comment Share on other sites More sharing options...
Pete M Posted October 11, 2022 Share Posted October 11, 2022 did you send them photos? because that clearly doesn't work. Link to comment Share on other sites More sharing options...
vanquishings Posted October 12, 2022 Author Share Posted October 12, 2022 21 hours ago, Pete M said: did you send them photos? because that clearly doesn't work. I did, same photos I posted here, actually. They asked what ujoints I tried, then told me to return it. Let's hope I have better luck with the used one. Link to comment Share on other sites More sharing options...
gogmorgo Posted October 12, 2022 Share Posted October 12, 2022 I’m curious what they come back with after they get it, if they update you that is. Did you take any measurements? I’ve occasionally had ujoint yokes bend on me, although never enough I couldn’t get the ujoint into it. There’s a possibility it got squeezed a bit in shipping I guess. Link to comment Share on other sites More sharing options...
vanquishings Posted October 12, 2022 Author Share Posted October 12, 2022 18 hours ago, gogmorgo said: I’m curious what they come back with after they get it, if they update you that is. Did you take any measurements? I’ve occasionally had ujoint yokes bend on me, although never enough I couldn’t get the ujoint into it. There’s a possibility it got squeezed a bit in shipping I guess. I doubt they'll follow up. Sadly, I didn't take any measurements, I was just about over it when I put it back in the box. Probably should have, but the newer one from C&M did look a bit different than the one I pulled off of the truck. the C&M had a flare on the inner edges of the yoke, and mentioned it was for a wrangler. No XJ/MJ mention, but it was a 40611. Used one should be here in friday. Crossing my fingers. Link to comment Share on other sites More sharing options...
PIKE Posted October 12, 2022 Share Posted October 12, 2022 Kind of late here too. I just went through my 89 D30 axle. To change to a one piece axle I went with 1997 ZJ CV shafts. At $45.00 a Piece what did i have to loose. They come stock on a V8 Grand Cherokee. I have a 97 Grand Cherokee V8 and used the same shafts and they have been going good.. Never had a problem. That's why I decided to use them for my CAD delete conversion. No problems at all. Must say I am not a rock crawler, but I do have 33r10.5-33 on my MJ. So far great. FYI You have to remove the ABS tone rings. They are pressed on, no big deal. Any way just my 2 cents https://www.rockauto.com/en/moreinfo.php?pk=534817&cc=1182237&pt=2288&jsn=919&_nck=Ekt6BqBF1pwlXdx0gYlm1esw98pF26vehMm%2FGG3C%2Fl2QOXSJubi7WSpUmUSdg3OxWOs2f5z9h422EONy36O0PjCuaadDqI1r86y%2FvJ1lBqy8eOR0sg7BszdZN4sjtsowhx3trFNVkOC9ShEq4yvq9czhtKw7wHUD4tkai4dC6ChdwdIF6%2Blha7y3cZF0JchS%2Bisd9bp8CJWvYpk1E%2Fhj3sa08%2FC%2Fj%2FbHeocDrxJN5lDcbhXQOhnOg4SPFhGgwR2TbbN1ScHVqLCU5ts8z0q76uU7F%2FchlNUPDT09Qgcm%2BXDoY7KIeaFmmz0MXsjCHgp%2Fgem2jgs0S5wwSY7eXEKdMbHm8mRNK7SHggWde4G%2FiRFz3ZjY9tolWl0vT%2F1%2FKpwGN%2BZ1KWsZYmO1yGRFJ%2BWsWQ%3D%3D Link to comment Share on other sites More sharing options...
zomeizter Posted October 13, 2022 Share Posted October 13, 2022 1 hour ago, PIKE said: Kind of late here too. I just went through my 89 D30 axle. To change to a one piece axle I went with 1997 ZJ CV shafts. At $45.00 a Piece what did i have to loose. They come stock on a V8 Grand Cherokee. I have a 97 Grand Cherokee V8 and used the same shafts and they have been going good.. Never had a problem. That's why I decided to use them for my CAD delete conversion. No problems at all. Must say I am not a rock crawler, but I do have 33r10.5-33 on my MJ. So far great. FYI You have to remove the ABS tone rings. They are pressed on, no big deal. Any way just my 2 cents https://www.rockauto.com/en/moreinfo.php?pk=534817&cc=1182237&pt=2288&jsn=919&_nck=Ekt6BqBF1pwlXdx0gYlm1esw98pF26vehMm%2FGG3C%2Fl2QOXSJubi7WSpUmUSdg3OxWOs2f5z9h422EONy36O0PjCuaadDqI1r86y%2FvJ1lBqy8eOR0sg7BszdZN4sjtsowhx3trFNVkOC9ShEq4yvq9czhtKw7wHUD4tkai4dC6ChdwdIF6%2Blha7y3cZF0JchS%2Bisd9bp8CJWvYpk1E%2Fhj3sa08%2FC%2Fj%2FbHeocDrxJN5lDcbhXQOhnOg4SPFhGgwR2TbbN1ScHVqLCU5ts8z0q76uU7F%2FchlNUPDT09Qgcm%2BXDoY7KIeaFmmz0MXsjCHgp%2Fgem2jgs0S5wwSY7eXEKdMbHm8mRNK7SHggWde4G%2FiRFz3ZjY9tolWl0vT%2F1%2FKpwGN%2BZ1KWsZYmO1yGRFJ%2BWsWQ%3D%3D Yeah man, I almost went this route before I pulled the trigger on the chromoly kit, but I got a good bundle deal at the time so I could not pass it up. One of my homies did what you did to his XJ and the process was easy peasy... Link to comment Share on other sites More sharing options...
vanquishings Posted October 13, 2022 Author Share Posted October 13, 2022 Forgive my ignorance, but what exactly is the process of doing a CAD remove? Is there a write up somewhere? You just swap the inners/outers with the $45 ones and remove the ABS ring? Can't be that easy.... Link to comment Share on other sites More sharing options...
zomeizter Posted October 13, 2022 Share Posted October 13, 2022 In my case, I removed the CAD axle, the sleeve, the fork, the vacuum box and all related hoses. I left the support bearing in the axle housing, installed new seals and moly shafts and covered up the CAD hole with an aluminum plate included in the kit, done. Link to comment Share on other sites More sharing options...
Pete M Posted October 13, 2022 Share Posted October 13, 2022 I think there's a writeup in the link in my signature. and yeah, it is that easy. hardest part is usually getting the old stuff out if it's rusted or original. Link to comment Share on other sites More sharing options...
PIKE Posted October 13, 2022 Share Posted October 13, 2022 https://www.amazon.com/SKF-11800-Small-Style-Diameter/dp/B00CLIWKAM/ref=sr_1_1?crid=1ZRALXCPDEMW8&keywords=SKF+11800&qid=1665669080&qu=eyJxc2MiOiIwLjAwIiwicXNhIjoiMC4wMCIsInFzcCI6IjAuMDAifQ%3D%3D&s=automotive&sprefix=skf+11800%2Cautomotive%2C159&sr=1-1-catcorr This is the seal you need for the passenger side of the differential. Getting it installed was the hardest part for me doing the conversion. Link to comment Share on other sites More sharing options...
ratrapp Posted October 13, 2022 Share Posted October 13, 2022 exactly.you need to remove both axles to pull the carrier out to install the seal.its not super hard,just time consuming. Link to comment Share on other sites More sharing options...
Andy in Pa Posted October 19, 2022 Share Posted October 19, 2022 If you left the grease seal from that u-joint cap on the u-joint trunion, believe it or not, that is enough to not allow the trunion already through the cap hole NOT go in far enough for the opposite side to slip into place. Once the grease seal is off, the slight edge of the center "black" part of the u-joint has to go into the cap hole, and it slips into place. Link to comment Share on other sites More sharing options...
