2005-2010 jeep commander, they have 4 per vehicle, and theyre 6$ used on Ebay, and i bet even cheaper at a pick-n-pull. ill measure mine tomorrow, my daily is a 2007 commander.
13 hours ago, Jeepman73 said:
I just bought a 91 mj from California.  Needing a replacement Interior light...any thoughts?
If these Commander lights fit they would be a good option, they look a little bit too big to me though. I have a pair of Mk5 VW Golf dome lights that work well in mine. Mk4 and I think Mk3 have the same dome lights. They look different, but fit the same hole.
I have several of these Commander lights.  They are to big to fit the stock opening.  If you are ok with modifying your stock opening, they might work, although I think the S10 Blazer cargo lights are a better option.
comparing the size differences between a stock MJ and XK interior\courtesy lights. ill be going this route to replace mine in my restomod project 10BEARS. i think this is the best route for me because they are Jeep parts for one, and they are plentiful and very cheap. this XK light was 10$ shipped to my door, and id imagine even less money at pic-n-pull. the actual install in the interior panel will be shown on my build thread on here.IMG_0201.jpg.39e84f09335eedea124a8e2ef4fbc959.jpgimage4_1.jpeg.2766e5b45d84584a57624900f6f52217.jpegimage3_1.jpeg.f3932be8c21e8250760af6f2d6855d2d.jpegimage2_1.jpeg.1c33c895937df533f549c2aa85bc4509.jpegimage1_1.jpeg.60113cea688e235dfd9bf04478bc8884.jpegimage1_1.jpeg.60113cea688e235dfd9bf04478bc8884.jpegimage0_1.jpeg.f2a5a6cdbab9e288b7d43a12fed0b050.jpeg
