70barracuda Posted April 4, 2022 Posted April 4, 2022 Have the nicer quartz clock out of an 86 and want to put it in my 88. 86 had blue connector with 5 wires, 88 had black connector with 4 wires. Found the gojeep page about the clocks and wiring diagrams and it seems I really only need to connect Red, blue, and ground to make it work. I don't need the dim function. Anyone do this swap? Just want to make sure I'm correct in the wires.
eaglescout526 Posted April 4, 2022 Posted April 4, 2022 I have a DIY page on converting the older style clocks. Every single one I did I have had great success except one member got one from me and the clock grew brighter until the display stopped working which is an interesting fault that I have no idea what caused it. But every clock I tested have worked with no issues.
eaglescout526 Posted April 4, 2022 Posted April 4, 2022 Or I have a wanted page where I do trades for the older style as a core and can send a converted one along. You’re call.
70barracuda Posted April 5, 2022 Author Posted April 5, 2022 I was able to depin and save the plug and retainer. Ordered some new pins and will connect everything up according to your right up. Thanks!
dasbulliwagen Posted April 5, 2022 Posted April 5, 2022 I did it years ago. I spliced in the newer style connector and kept the old one on too, so I can swap if needed to either style.
Minuit Posted April 6, 2022 Posted April 6, 2022 For anyone who might not know the "why" for this since I don't think the clock thread has been linked yet: the "Quartz" and 1991 clocks have vacuum fluorescent displays which are much more aesthetically pleasing and much easier to read than the LCD clocks of other years. Here's a Quartz clock out of an '87 (which had the Metri-Pack connector on it already) in my '89: and here's the 1991 clock, which uses a different connector but also works the same way. Here is an LCD clock with a fresh bulb in it:
Limeyjeeper Posted April 6, 2022 Posted April 6, 2022 This is also a useful link http://gojeep.willyshotrod.com/HowtoDashClock.htm
