wadebishop Posted January 27, 2022 Share Posted January 27, 2022 I'm getting trashy gas milage!!! Any ideas how to get that better?? [I've replaced injectors] Link to comment Share on other sites More sharing options...
Pete M Posted January 27, 2022 Share Posted January 27, 2022 how bad? Link to comment Share on other sites More sharing options...
wadebishop Posted January 27, 2022 Author Share Posted January 27, 2022 seems like 10mpg in the city --- feel like i go through a lot of gas! Link to comment Share on other sites More sharing options...
MiNi Beast Posted January 28, 2022 Share Posted January 28, 2022 How many miles do you get per full up? All sorts of things contribute to poor gas mileage. Box jeep design, cad, fuel filter, air filter, dirty intake, carbon buildup in the engine, weak spark, oversized tires, gearing, poor fluids, lead foot, bad timing and thats what i got off top of my head. Start there and keep us updated on your progress. Link to comment Share on other sites More sharing options...
87MJTIM Posted January 28, 2022 Share Posted January 28, 2022 Year? Eng? Trans? 2x or 4x? Link to comment Share on other sites More sharing options...
wadebishop Posted January 28, 2022 Author Share Posted January 28, 2022 sorry...1988, i6, 4x4 [not sure the trans?] Link to comment Share on other sites More sharing options...
wadebishop Posted January 28, 2022 Author Share Posted January 28, 2022 2 hours ago, MiNi Beast said: How many miles do you get per full up? All sorts of things contribute to poor gas mileage. Box jeep design, cad, fuel filter, air filter, dirty intake, carbon buildup in the engine, weak spark, oversized tires, gearing, poor fluids, lead foot, bad timing and thats what i got off top of my head. Start there and keep us updated on your progress. THX! I get about 180 miles to a tank [16gal] Standard tires Good Fluids I'll have to check the rest! Link to comment Share on other sites More sharing options...
MiNi Beast Posted January 28, 2022 Share Posted January 28, 2022 Yeah you should get atleast 300. Ummm, check things out and we'll go from there. Link to comment Share on other sites More sharing options...
MiNi Beast Posted January 28, 2022 Share Posted January 28, 2022 Would that be automatic or manual? Auto will be aw-4 and manual could be the puke-5 or ax-15. Link to comment Share on other sites More sharing options...
87MJTIM Posted January 28, 2022 Share Posted January 28, 2022 Possibly stuck in open loop with long term fuel trims very high. You will need to perform more tests to understand these engines and fix the problem. Do you have a Nickintimedesign REM yet? If not, it is well worth getting. Also, download the electrical and Renix fuel system manuals from the DIY section. Link to comment Share on other sites More sharing options...
gogmorgo Posted January 28, 2022 Share Posted January 28, 2022 cruiser54.com if you haven't been there already. Make sure your ignition components are all in good shape, spark plugs, wires, cap and rotor. If you don't know how old they are best to go ahead and change them. There's another recent thread about fuel economy that's worth a skim. Link to comment Share on other sites More sharing options...
wadebishop Posted January 28, 2022 Author Share Posted January 28, 2022 Thx everyone for the help! I’ll get started (although it’s -21 today🥶🥶🥶) I’ll let you know Link to comment Share on other sites More sharing options...
gogmorgo Posted January 28, 2022 Share Posted January 28, 2022 If you're leaving it idling for extended periods due to the cold, or running in 4x4 a bunch, that'll tank your MPG pretty hard too. 10 is still pretty low, but in winter if I was getting 14mpg out of my 4.0 MJ I was smiling. The engine is coming up to temp, yes? Link to comment Share on other sites More sharing options...
75sv1 Posted January 28, 2022 Share Posted January 28, 2022 I usually only post my highway mileage. Also, is yours manual or auto? It makes a different of at least +2-3 mpg with a manual. Also, tire size. I'd also see what the tire psi is. They deflate in the cold. I'd say I get 14 mpg in mixed driving and 18 mpg with my 2000 XJ on 31's and an auto. I'd get 23 mpg with my stock '88 MJ and a manual trans. Also, what temps if the engine running at? I do get less MPG in the winter and colder months. Link to comment Share on other sites More sharing options...
Pete M Posted January 28, 2022 Share Posted January 28, 2022 plus your foot matters a lot. my first MJ was only 10 years old at the time I got it and I regularly got ~12 mpg for, um, reasons. but a long freeway drive would give me around 20 so I didn't much worry about it. Link to comment Share on other sites More sharing options...
EUREKA Posted January 30, 2022 Share Posted January 30, 2022 On 1/27/2022 at 7:54 PM, 87MJTIM said: Possibly stuck in open loop with long term fuel trims very high. You will need to perform more tests to understand these engines and fix the problem. Do you have a Nickintimedesign REM yet? If not, it is well worth getting. Also, download the electrical and Renix fuel system manuals from the DIY section. I can't wait to get one of the clock panel ones. Link to comment Share on other sites More sharing options...
87MJTIM Posted January 30, 2022 Share Posted January 30, 2022 4 minutes ago, EUREKA said: I can't wait to get one of the clock panel ones. Link to comment Share on other sites More sharing options...
