EUREKA Posted January 16, 2022 Share Posted January 16, 2022 Purchased in 2018. Has been my daily driver for about 3 years after selling my ZJ. This has been my first Renix after owning 3 ZJ's and 3 XJ's and a WJ. I no longer drive off-road as a hobby but I still use 4WD to access work/fishing locations. Only a few days after returning from a long trip to purchase my 91 MJ, this 1988 MJ came up on my local Craigslist for sale. I had to go take a look. Ended up trading my 84 Yota straight over for the 88 MJ. Here is what I've done to her so far; - Throttle body and IAC cleaning (I always do it right away when I buy a new 4.0 jeep) - New Renix vacuum harnesses (Cruiser's tip #22) - Replaced and set TPS (Cruiser's tip #8) - MAP sensor - O2 sensor - Cap/rotor - Plugs and wires (8mm) - 89 ECU upgrade / ECU connector refreshing (Cruiser's tip #9) - Big 7 wire upgrade (Jeep Cables) / Ground refreshing (Cruiser's tip #1) - Improved fuel pump ground (Cruiser's tip #29) - Remanufactured 4 Port Fuel Injectors (k suspension) - Fuel PSI regulator - Replaced Headlight Switch - Connector and relay/receptacle refreshing (tip #3) - LED headlight upgrade - LED turn signal/parking/marker lights - LED B-pillar/added under dash courtesy/gauge - Added Sentinel Headlamp feature (Cruiser's tip #30) - Ignition switch (out of necessity) - Power Steering pump (out of necessity) - Shocks and steering dampener (KYB Gas Adjust) - Tie-rod ends/Draglink - Control arm bushings - Ball joints - Brake stuff (of course but no significant upgrades yet) - Had trans serviced by transmission shop - Converted to open cooling system (Cruiser's tips #33&34) (after blowing a hose in the middle of nowhere) - Luckily it blew near the end of the hose and I was able to cut it short and use it to get home) - Had the stereo shop install b-pillar/door speakers/deck - Had factory bench seat reupholstered (bench was better for my dog, unfortunately he passed away from old age) - Side and rear window tint (front has crack and can't be tinted) - Repaired loose steering column (had a shop do it because I was busy with work) - Cat back exhaust (Shop) - Replace broken exhaust bolts, 4 freeze plugs, Manifold gasket (Shop) Link to comment Share on other sites More sharing options...
EUREKA Posted January 16, 2022 Author Share Posted January 16, 2022 I'm not sure how to rotate the images. They look correct on my phone, desktop, paint 3D, photo editor, and imagur. I plan to do the Throttle body to MAP hose upgrade (tip 31), C101 connector elimination, and Sensor ground upgrade (tip #6) very soon. I have all the parts ready to go. The 4 hole injector upgrade and Big 7 made noticeable differences, as did the TPS adjustment. They were nothing compared to the difference of the ECU upgrade! That one has made a tremendous difference. In fact, before the ECU upgrade I was not convinced I would ever be happy with a renix jeep. My goals for the future: Headlight harness installation Trans plug connector refreshing (tip 10) (did the one under the dash) Improving blower motor performance (tip 28) Improving the instrument panel ground (tip 18) Full gauge cluster Renix Distributor indexing (tip 13) 97+ wiper arms Wiper bushings Replace antenna with more rugged one Service differentials Oil Filler cap Mod (tip 26) Get fog lights working (I don't understand why they are there but not wired) Add cargo light Rear defrost New windshield Paint job Line-x bed (I have used herculiner and it's not for me) Lumber rack Maybe a modest lift Fabricate protection / address departure angle Link to comment Share on other sites More sharing options...
EUREKA Posted January 16, 2022 Author Share Posted January 16, 2022 Link to comment Share on other sites More sharing options...
89 MJ Posted January 16, 2022 Share Posted January 16, 2022 Looks like a good truck. Someday I want an MT LWB to go with my regular SWB truck. Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 16, 2022 Share Posted January 16, 2022 Oh hell yeah! Rockin the same seat cover! Link to comment Share on other sites More sharing options...
EUREKA Posted January 16, 2022 Author Share Posted January 16, 2022 1 hour ago, eaglescout526 said: Oh hell yeah! Rockin the same seat cover! I grew up on riding on Mexican saddle blankets. Link to comment Share on other sites More sharing options...
EUREKA Posted January 16, 2022 Author Share Posted January 16, 2022 1 hour ago, 89 MJ said: Looks like a good truck. Someday I want an MT LWB to go with my regular SWB truck. I love the room since this is my work truck. Departure angle is frustrating though. I damn near ripped my bumper off getting to a worksite a while back. Link to comment Share on other sites More sharing options...
EUREKA Posted January 16, 2022 Author Share Posted January 16, 2022 Completed Cruiser's tips 3 (Connector and relay/receptacle refreshing ) and 4 (Coil/ICM contacts) yesterday. Looks like Ill be doing tips 2 - C101 connector elimination and 6 – Sensor ground upgrade today. Link to comment Share on other sites More sharing options...
EUREKA Posted January 17, 2022 Author Share Posted January 17, 2022 No more BS C101 or sensor ground splices. Found what looked like duct tape on my fuel injector ground splice. Also found that some well meaning person at one time had eliminated the factory sensor ground splices using a big butt connector. Got it all soldered and heat shrunk now. Link to comment Share on other sites More sharing options...
Pete M Posted January 17, 2022 Share Posted January 17, 2022 I've had success with rotating the image on my laptop, then rotating it back. Link to comment Share on other sites More sharing options...
EUREKA Posted January 17, 2022 Author Share Posted January 17, 2022 51 minutes ago, Pete M said: I've had success with rotating the image on my laptop, then rotating it back. I tried that. Tired rotating both 180 and 360. Link to comment Share on other sites More sharing options...
Pete M Posted January 17, 2022 Share Posted January 17, 2022 dang. the ones and zeros win again. Link to comment Share on other sites More sharing options...
EUREKA Posted January 24, 2022 Author Share Posted January 24, 2022 Did cruiser54 Tip 31-Throttle body to MAP hose upgrade today. I was getting tired of occasionally starting my truck and getting the crap scared out of me by a crazy high idle. Only seven more tips to go on the list now! Link to comment Share on other sites More sharing options...
EUREKA Posted January 29, 2022 Author Share Posted January 29, 2022 Not the smoothest day of wrenching today. Got a full gauge cluster swapped in, then realized that I neglected to account for polarity when I installed LED lights in the cluster. Also realized that I kinda like being able to dim the dash lights so I'm probably going back to incandescent. Plus the fuel gauge in the full cluster I installed doesn't seem to be working. This is a real bummer! Also got the wrong part from NAPA for the temp sensor that going in the intake manifold. The one I got looks very similar but is a larger thread size. I know that's not one that feeds the gauges but I wanted to swap it out anyway. Link to comment Share on other sites More sharing options...
EUREKA Posted January 29, 2022 Author Share Posted January 29, 2022 At least I got the instrument panel ground upgraded successfully. Link to comment Share on other sites More sharing options...
Pete M Posted January 29, 2022 Share Posted January 29, 2022 did you mean to hide the post about paint? Link to comment Share on other sites More sharing options...
EUREKA Posted January 29, 2022 Author Share Posted January 29, 2022 14 minutes ago, Pete M said: did you mean to hide the post about paint? Yes, only because I'm getting ahead of myself. Link to comment Share on other sites More sharing options...
EUREKA Posted January 29, 2022 Author Share Posted January 29, 2022 Just swapped back in all the incandescents. Link to comment Share on other sites More sharing options...
EUREKA Posted February 2, 2022 Author Share Posted February 2, 2022 Bypassed the power comfort switch and checked the associated fuse. Only 6 of Cruisers tips remaining. 10 – Trans plug connector refreshing 19 – Headlight harness installation 28-Improving blower motor performance 38-Improving the wiper motor ground 29-Improving the fuel pump ground 35-Reducing cabin wind noise 38-Improving the wiper motor ground Link to comment Share on other sites More sharing options...
Pete M Posted February 2, 2022 Share Posted February 2, 2022 some fun ones coming up! or at least ones that you should be able to see an immediate improvement and smile. Link to comment Share on other sites More sharing options...
knever3 Posted February 2, 2022 Share Posted February 2, 2022 I have never seen someone go through and document Cruiser's tips. Great work!! Link to comment Share on other sites More sharing options...
EUREKA Posted February 7, 2022 Author Share Posted February 7, 2022 On 2/2/2022 at 5:07 AM, knever3 said: I have never seen someone go through and document Cruiser's tips. Great work!! Thanks! Link to comment Share on other sites More sharing options...
EUREKA Posted February 7, 2022 Author Share Posted February 7, 2022 Checked off tip #10 today. "Trans plug connector refreshing". Made sure to also check the connector under the dash and the fuse. Also did #29 "Improving the fuel pump ground". I did it slightly siferntly. Instead of exposing some copper on the existing ground wire and warping the new ground around it, I cut the original wire, twisted both cut ends together with the new wire and soldered them. After soldering I slathered it in oxgard and put a piece of heat shrink on it. Not sure if everyone knows this but if you cut a piece of heat shrink with diagonal cutters while it is hot, it will melt the end of the tube closed. I also soldered on the ring terminal insted of just crimping it. Also removed the fuel filter mount and cleaned between the mount and the frame with a wire brush, as well as the screw itself before oxgarding everything. Link to comment Share on other sites More sharing options...
EUREKA Posted February 7, 2022 Author Share Posted February 7, 2022 I had no idea that the HVAC panel has a light. This is my first pre-91 jeep and I just assumed that the HVAC panel was not lighted. I happened to see one for sale while browsing and noticed what looked like a light bulb mounted in it. That should make things a bit easier to adjust at night. Link to comment Share on other sites More sharing options...
EUREKA Posted July 8, 2022 Author Share Posted July 8, 2022 Been a while since I completed one of @cruiser54 tips. Just did the wiper motor ground improvement, and changed the bushings ect. Trans plug connector refreshing and fuel pump ground upgrade are also done. Tips remaining; 13 – Renix Distributor indexing 19 – Headlight harness installation 21 – Renix EGR valve test 23 – CPS timing advance mod 25 – Valve cover mod 26 – Oil Filler cap Mod 28- Improving blower motor performance 35- Reducing cabin wind noise Link to comment Share on other sites More sharing options...
