Pete M Posted December 10, 2021 Share Posted December 10, 2021 so I found this in a 90s XJ and it has the codes on the back. but it's a little bit... crumpled. and fragile. any ideas on how to get it into a legible flat piece of paper again? I'm having flashbacks to an episode of MacGyver, but haven't quite worked up the guts to squirt it with water... Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted December 10, 2021 Share Posted December 10, 2021 How about a humidifier in a small closed in area, to make the paper More pliable Link to comment Share on other sites More sharing options...
AZJeff Posted December 10, 2021 Share Posted December 10, 2021 A warm (not hot) clothes iron will also help remove the wrinkles. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted December 10, 2021 Share Posted December 10, 2021 Somehow it will have to be rehydrated as suggested. The thermal printing type may be another story. First and foremost though, it needs to be flattened. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 12, 2021 Share Posted December 12, 2021 https://www.sciencealert.com/one-of-the-dead-sea-scrolls-is-even-more-extraordinary-than-we-thought Link to comment Share on other sites More sharing options...
Pete M Posted December 12, 2021 Author Share Posted December 12, 2021 this is what I ended up doing. spritz it with a bit of water, slowly unfold it on a cooking sheet, then carefully compress with a book (with a plastic cover so it won't stick) and let dry. so far so good. just got the top bit to do today and then I can put it into a plastic sleeve. I thought about laminating it, but I fear that if anything goes wrong, it'll go very very wrong. I'm looking forward to examining the codes on the back. Link to comment Share on other sites More sharing options...
CMMagnussen Posted December 14, 2021 Share Posted December 14, 2021 On 12/12/2021 at 9:09 AM, Pete M said: this is what I ended up doing. spritz it with a bit of water, slowly unfold it on a cooking sheet, then carefully compress with a book (with a plastic cover so it won't stick) and let dry. so far so good. just got the top bit to do today and then I can put it into a plastic sleeve. I thought about laminating it, but I fear that if anything goes wrong, it'll go very very wrong. I'm looking forward to examining the codes on the back. Ugh.. that orange book is giving me flashbacks. Link to comment Share on other sites More sharing options...
