WTB: spare tire wench.
Sir Sam
5 hours ago, FrankTheDog said:
On 11/13/2021 at 11:38 AM, MiNi Beast said:
Looking for the wrench itself or the assembly under the bed? I have  the assembly under my bed i don't use. :dunno:
now that you mention it, I don’t have the wrench/crank either.
On 11/13/2021 at 1:02 PM, eaglescout526 said:
I have an entire short bed assembly. With powder coated bracket.
Didn’t realize long and short were different. How different is the short bed? Ive got long bed.
Are you looking for a spare tire winch?
Ha, didn’t realize what I did before. I guess I’m also looking for a winch.
not only are long and short different, some years mounted to the frame, other mounted to both the frame and bed.  I wish I had taken better notes as I pulled all these beds. :(  you'll want to crawl under and snap pics to help buy the correct one. :L:
The winch itself is the same between Lwb and Swb .
The lwb setup doesn’t have a bracket and the winch tube is longer . The lwb  tube caN be cut down and used on the swb trucks . The winch only bolts to the “X part of the frame .
On the swb setup has the extra bracket That bolts to both the frame and the bed. The winch bolts to that bracket .
