1991 Comanche 4.0L automatic column shift, 4X4 long wheelbase, metric ton 36,100 original miles. I have owned six XJ's over the years. This is my first Commanche "I'm so excided!". This Commanchee truck has spent its entire life as a snow plow truck for a school district in Boulder, Colorado. I bought it from an auto dealer here in Southern Colorado with the snow plow still attached. I drove it home it starts, runs and drives good. The body is in rough shape with many dents and scratches, needs lots of cleaning everywhere.
I plan on starting on the inside pulling the seat, rubber floor mat, headliner and trim. Fix everything and put it back togather origanal.
The glove box was stuffed with 30 years of paperwork including most of the annual emissions reports and origanal window sticker.
IMG_20210815_124035.jpg.8878eee6fff3db50e1ee3ec7a420b90c.jpgIMG_20210815_121754.jpg.631e043e0e66527246ce90b935caddcf.jpg
IMG_20210815_120810.jpg.bd16b0223abf34125fa7c3138b78ead1.jpgIMG_20210815_123849.jpg.2b29f5088ff9401902b532066bcc4197.jpg
IMG_20210815_122154.jpg.5a7a47f8278df8bc7dace0bd91df3fe4.jpgIMG_20210814_011704.jpg.cbc7c6a07379bd25244ff402036a44a7.jpg
love that rear bumper. :D  I bet that truck has some stories it could tell.
one "M", one "E".  no need for all those extra letters in "Comanche". :L:
I removed the floormat looks like water is leaking in on the driver side of the cab somewhere. I will replace the floor pan and headliner, then put it back together. Should turn out good on the inside.IMG_20210820_111344.jpg.943e18f1985ba5cdc507cce2a35f201d.jpgIMG_20210820_110134.jpg.558715c49fb77ba499fa9a4b189818fc.jpg
On 8/28/2021 at 12:38 PM, Blade said:
I am growing to like that back bumper. I think with a little work it's a keeper.
it certainly is unique   :D
I am done with the inside, replaced the headliner material, rebuilt both sun visors with the same material, repaired the left side floor pan, deep cleaned.IMG_20210905_165337.jpg.9c9acb5e13a0e4db1f29a9d08515f143.jpgIMG_20210905_165356.jpg.6008ae1fafc985445f38cecc4809a239.jpgIMG_20210905_165410.jpg.a8a77ea165fe1e9a97a0dc347fa5c206.jpgIMG_20210905_165429.jpg.2d38d792d47afa35044141e96749c5f7.jpgIMG_20210905_165450.jpg.0d9456b5f715d2eefa83dc3870fbde43.jpgIMG_20210905_165536.jpg.1f9d80f3c782f4aa775d71b2396442fc.jpgIMG_20210905_165559.jpg.542129c7c637687d3a9ab570ce9eae41.jpgIMG_20210905_170013.jpg.bc255fd4ec2335868e40e8f2c3e945a9.jpgIMG_20210906_154937.jpg.f3628c10f9181774ad50afdb2bb97916.jpg
Working under the hood now. Deep cleaned the engine compartment, repaired engine oil leaks, valve cover gasket, filter adapter, rear main seal, and oill pan gasket. Removed the snow plow and all of the PO wiring and switches.IMG_20210919_121451.jpg.9a43ab0c89d8562ab87a43a16f3ab2c8.jpg
Found a dead Comanche nearby.
I salvaged a left rear tail light, inside dome light and front grill.
I have not added it. I'm unsure about the year, I did however get the VIN 1J7GJ26L8LL129293
just put it in the 91 subforum with the VIN as the title and we'll move it later if needed. :L:
Making progress, finished under the hood and front clip. Fixed or replaced all broken and missing parts. Replaced the front header, left front fender, 8 slot grill, front valance, right and left front inner fenders also installed 1996 Cherokee non break-away mirrors both sides. Next I plan on working on the rear bumper, rear flares, mud flaps and changing all of the fluids.
  • 1 month later...
I've been browsing the Members Projects forum ...
You've really done some nice work cleaning that truck up!
  • 3 weeks later...
Straitened rear bumper, replaced diamond plate on top, fabricated and added a class 3 receiver hitch. Repaired broken bolts on the rear fender flares and mud flaps.
Changed fluids front/rear differential, transfer case, transmission.
Upgraded headlight wire harness, H4 ceramic connectors, 30amp relays, 12 guage wire.
Started body work, planning on painting original color, PW7 bright white.IMG_20211218_164649.jpg.340efe0eb867fcf636492ea17cc56f6a.jpgIMG_20211218_164608.jpg.88815af0fa2b17f1441998f23a23b311.jpgIMG_20211218_164549.jpg.e75b0dec1d2c16fb90f23019c650d5a3.jpgIMG_20211218_164941.jpg.4fb82f533c93d1b95663424dd8f984a5.jpg IMG_20211218_164649.jpg.340efe0eb867fcf636492ea17cc56f6a.jpg
Thanks, I added front header chrome Jeep emblems to the rear mud flaps. It is a fit, the lettering happens to be the same size and style.
  • 1 month later...
Continuing to work on body panels, it has been a long process. Still have much more to do. Removed the door latches, both latches we're gummed up with dirty dried grease, or what ever lube was used on them. I power washed and soaked them in ATF fluid. Replaced the brittle plastic rod clips. Latches are working like new again.IMG_20220130_143642.jpg.0fba91b1e34245969e932e52c6f30eed.jpgIMG_20220130_143625.jpg.ce6d45d50d58ac6e312fc2042bd617b0.jpgIMG_20220130_143636.jpg.dcc990f193bbfa6bf4bedc0f42d26361.jpgIMG_20220130_143650.jpg.9fa9b8fe84ce9b03fd2e4f6f50f0e316.jpg
Any chance you could get stone measurements for where your you're mirrors mount? And maybe a pic or two of where the interior door brace mounts?  I have a set of tow mirrors in want to mount but haven't found good reference photos.
can you do a quick writeup about the latches for the DIY?  we need to get the word out about how straight forward it is to refresh them. :D
