jtdesigns Posted November 17, 2007 Share Posted November 17, 2007 I want to replace my door jamb switch. Wildman told me napa can get them, but they aren't the exactly the same.. The jeep one has 2 connectors I'm thinking it's because it's not a ground switch like gm uses. Neways here is the one listed at napa,,, Is the jeeps a grounded circuit? http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=ECH&PartNumber=DJ6137&Description=Door+Jamb%2fAjar+Switch I found these on ebay looks like the jeeps but listed for dodge.. I'm pretty sure it's the same but the price is about 50% more... http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=007&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=170168573366&rd=1 What'ch think??The napa one or bite it and go for the ebay one?? Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 17, 2007 Share Posted November 17, 2007 The left side door switch is a two contact normally open switch. It applies a ground to the interior lights from one contact; the other contact goes to the chime module (Lights ON alarm). The right side door switch is a single contact switch, it applies a ground to the interior lights only. Link to comment Share on other sites More sharing options...
Eagle Posted November 17, 2007 Share Posted November 17, 2007 I want to replace my door jamb switch. Wildman told me napa can get them, but they aren't the exactly the same.. The jeep one has 2 connectors I'm thinking it's because it's not a ground switch like gm uses. Neways here is the one listed at napa,,, Is the jeeps a grounded circuit? Yes, the Jeep door post switch is in the grounded side of the circuit, and completes the ground when the door is opened. There are actually two -- the passenger door should have a single contact, the driver's door should have two contacts. Link to comment Share on other sites More sharing options...
jtdesigns Posted November 17, 2007 Author Share Posted November 17, 2007 The left side door switch is a two contact normally open switch. It applies a ground to the interior lights from one contact; the other contact goes to the chime module (Lights ON alarm). The right side door switch is a single contact switch, it applies a ground to the interior lights only. Yes, the Jeep door post switch is in the grounded side of the circuit, and completes the ground when the door is opened. There are actually two -- the passenger door should have a single contact, the driver's door should have two contacts. Thanks guys!!! That makes sense, I didn't even think about the the buzzer... Link to comment Share on other sites More sharing options...
Wildman Posted November 17, 2007 Share Posted November 17, 2007 NO.......Wildman don't buy from Napa, and he told you Advance has the door jamb switch :D The switch is - GP Sorensen # JS39 $3.56 And it should be a stock item in the store. Advance store that is ;) Link to comment Share on other sites More sharing options...
WahooSteeler Posted November 17, 2007 Share Posted November 17, 2007 you can also get these switches at teamcherokee.com and wholesalemopar.com Link to comment Share on other sites More sharing options...
87 Comanche dude Posted January 31, 2025 Share Posted January 31, 2025 I can locate the 2 contact door jamb switch (GP Sorensen JS39). Thanks Wildman! But where do I find the passenger side single contact switch? Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted February 1, 2025 Share Posted February 1, 2025 (edited) From reading this thread, the passenger side is just 1/2 of the driver side. So if you don't find the passenger side, seems like you could probably use the same switch, just only use two of the 4 contacts. You can use an ohm meter to find two connections that are closed (connected, 0-ohms) before you depress the switch and open (disconnected, infinite ohms) when you press it. If there are only 3 contacts on the driver side switch, then I would assume it uses a common ground connection. The determination of which 2 contacts to use would be the same. Edited February 2, 2025 by AnotherOldJeepGuy Add 3 Prong Case Link to comment Share on other sites More sharing options...
knever3 Posted February 12, 2025 Share Posted February 12, 2025 Well, this thread may be why my buzzer never worked, maybe I have the wrong switch on the drivers side, or the wires are wrong. Thanks!! Link to comment Share on other sites More sharing options...
