1J7GT36L9KL560588
tugboat95
Saved one from the crusher. However it's been registered as scrap and can never be titled again. This Jeep is completely fixable. Frame is good, no rust on the bed, floor pans are good. Small amount of rust on cab corners and hood. It does not run but will start with starting fluid. 4.0l, 5 speed. 120k miles. Big score with the service manuals. Even got the tail lights. I'm not sure if I'm keeping it for parts or this would be a good candidate to convert to 4x4, jack it up and make a trail rig. Maybe a little bit of both.052efd8ba0aed856deff3975b0fba041.jpge2c5a032a68da19676c2af7c2804b9de.jpg4cb3330e7dad62ce5593f20969ea69a5.jpg674df846d230860c4b105cf3435277a1.jpg106452ac6120c3c3ae0c07c32286d3c5.jpgb40cac6126368be3ad03c3aa2030025b.jpg4339c912c84cd3d73c3492b231908740.jpg
89 Comanche
Eliminator
2wd
4.0L
5 speed PukeGoat
Factory Original
*X1 TRIM STYLE X1 - CLOTH BENCH
-Q8
135 Zone 35-Washington
1AA U.S. Dealer Retail
4EA Sold Vehicle
4HC Special Scheduling Condition III
5AM Largo Tracking
5KN Metro Cars of Detroit
AHL Heavy Duty Insulation Group
ALN Body Color Group
APA Monotone Paint
BAQ 61 AMP ALTERNATOR
BCX Maint. Free Battery
BGA Power Front Disc/Rear Drum Brakes
BJA STD DUTY FRT DISC BRAKES
BKP 10x2.5 Rear Drum Brakes
CBA Straight Back Bench Seat
CKA Carpets - Floor and Cargo Area
CSR Passenger Assist Handles
CUM Mini Floor Console
DBB All Manual Transmissions
DDQ 5-Speed Manual Transmission
DMM 3.07 Rear Axle Ratio
DRK Dana 44/226MM Rear Axle
DSA Anti-Spin Differential Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEC Front Left Side Sliding Window
GFD Rear Sliding Window
GNA Rear View Day/Night Mirror
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HCD Do Not Use - See HCA
HGA Hood Insulation
JAA Instrument Panel
JAY DO NOT USE - See JP, KA classes
JBD BEZEL-I/PANEL CLUSTER - BRIGHT
JCA 85 MPH Primary Speedometer
JGB Digital Clock
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
JKB
K2X STRIPE/BADGE/MOLDING/COLOR
K3C STRIPE/BADGE/MOLDING/COLOR
KKE
LAF Seat Belt Alert-Driver Seat only
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Bumper
MDA Front License Plate Bracket
MFG Body Color Headlamp Bezels
MHA Black Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMK Lower Grille Surround-Painted Silver
NAA Federal Emissions
NBA LIGHT DUTY CYCLE
NBK EVAP Control System
NDA Catalytic Converter
NF5 Fuel Tank - 23 Gallon
PQ9 PRIMARY PAINT - HQ9
QQ9 SECONDARY PAINT - HQ9
RAA All Radio Equipped Vehicles
RAB AM/FM Radio
RCD 4 Speakers
SBA Power Steering
SCE Steering Wheel
SFB Front Heavy Duty Shock Absorbers
SGB Rear Heavy Duty Shock Absorbers
TAA All Tires
TAE
TBB Full Size Spare Tire
TBM Tire Carrier Winch
TRP Tires
WJD 15X7.0 Styled Steel Wheels
XBS Pickup Box
XFA -35F Protection Anti-Freeze
YAA Build To U.S. Mkt. Specifications
YGB 1 Additional Gallons of Gas
YGG 9 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1B GVW/Payload Rating
Z57 Left Front Spring Group Vii
Z77 Right Front Spring Group VII
Build date 3/29/89
Body code TM62
Sold by COASTAL MOTORS INC, GLOUCESTER VA
Thanks for the info. I was hoping it had the Asin tranny and not the Peugot. It has a decal on it saying Heavy duty 2250. Does it have the metric ton? It does have the dana 44 axle. Truck has been in a field somewhere since 2002. At least that's the last state inspection sticker. Body is extremely straight and the bed is awesome. I think the camper shell is the Comanche specific. It's a perfect fit. Too bad the junkyard had already listed it as scrap and it can't be retitled. Windshield is junk but rest of glass is good. I think it is a good candidate to turn into a trail rig.
89 Comanche
Eliminator
2wd
4.0L
5 speed PukeGoat
Factory Original
I went through and cleaned up the common reused codes for ya. :L:
can you share a pic of the leafs?  4+1 and 3+2 were the metric ton varieties.  3+1 is the normal leaf pack.
you build date indicates you have the AX-15. :D  3-9-89 was the last of the peugeots.
you build date indicates you have the AX-15.   3-9-89 was the last of the peugeots.
Your right About the tranny. I had totally misread that date. My other one was built on 3-6-89 and is literally one of the last ones. I'll try to get a pic of the leads this weekend.
89 Comanche
Eliminator
2wd
4.0L
5 speed PukeGoat
Factory Original
20 minutes ago, Pete M said:
metric tons were all longbeds.  but parts can be swapped around.
Its a long bed.  Thought I had bought a short bed with the dana 44.  I just measured the bed.  Its just over 7 foot long.  Thing full of surprises.  I just hooked up a battery and all the lights and stuff came on.  Wouldn't turn over though.
It is a factory metric ton, the G (GVWR, 5001-6000) in 4th position of the VIN confirms it, an F would be standard payload (GVWR, 4001-5000). And the 2 in the body code that eaglescout526 listed is for a LWB.
Step one: buy most rusty mj you can find.
Step two: dash swap the 2 trucks
Step three: THIS IS THE IMPORTANT ONE!!
Don't do this.
Lol...yeah, I just don't know. I'd love the trail rig idea but I don't have anywhere within 6 hours of me to ride it. And I don't own a trailer. There are a ton of good parts on this truck. And it's completely fixable. No rust in the floorboards. Small amount in cab corners. Engine turns over but I don't know the fuel system status. Ain't nothing that can't be fixed or put on a third truck my wife would kill me if I buy.
89 Comanche
Eliminator
2wd
4.0L
5 speed PukeGoat
Factory Original
