james-mc Posted April 14, 2021 Share Posted April 14, 2021 I'm trying to install the new harmonic balancer since the old one was flinging rubber and scratching my timing cover. Its a 1989 Jeep Comanche with the 4.0 Inline 6. I managed to get the old one out with my handy dandy harbor freight wheel puller set. It had enough clearance that i didn't need to remove anything major like the radiator. Now I'm trying to install the new one. But it doesn't go onto the crankshaft far enough to thread the bolt like I've seen in some videos. I am reusing the old key. Its stuck on the shaft pretty good. I used a set of calipers to make sure the hole diameter is the same. Any tips for getting the harmonic balancer installed? Also has anyone used the loaner installer from o'reilly's? Its pretty cheap to rent so I might be better off doing that. This is the Harmonic Balancer I bought: https://www.napaonline.com/p/NDP6005229?vehicleAddPDP=true Link to comment Share on other sites More sharing options...
jdog Posted April 14, 2021 Share Posted April 14, 2021 Yeah rent the tool it makes it a lot easier Link to comment Share on other sites More sharing options...
james-mc Posted April 14, 2021 Author Share Posted April 14, 2021 8 minutes ago, jdog said: Yeah rent the tool it makes it a lot easier Sounds like a plan. I hope the evertough oreillys has for rent does the job Link to comment Share on other sites More sharing options...
jdog Posted April 14, 2021 Share Posted April 14, 2021 Just check the bearing and make sure it's good. But there isn't to much to go wround worth the tool Link to comment Share on other sites More sharing options...
Minuit Posted April 14, 2021 Share Posted April 14, 2021 The tool I have is identical to the one you can rent from the parts stores. Makes the job a lot easier and is safer for the crankshaft. A little bit of oil on the installer tool's threads will help too. Also, make sure the last guy to have it didn't mess it up. Make sure the threads aren't damaged. Link to comment Share on other sites More sharing options...
james-mc Posted April 14, 2021 Author Share Posted April 14, 2021 18 minutes ago, jdog said: Just check the bearing and make sure it's good. But there isn't to much to go wround worth the tool Bearing looked ok from what I've seen. Wasn't leaking before i pulled the old HB off. Link to comment Share on other sites More sharing options...
james-mc Posted April 14, 2021 Author Share Posted April 14, 2021 17 minutes ago, Minuit said: The tool I have is identical to the one you can rent from the parts stores. Makes the job a lot easier and is safer for the crankshaft. A little bit of oil on the installer tool's threads will help too. Also, make sure the last guy to have it didn't mess it up. Make sure the threads aren't damaged. Awesome thanks. Ill check it out and make sure threads arent damaged before i rent it. Link to comment Share on other sites More sharing options...
jdog Posted April 14, 2021 Share Posted April 14, 2021 8 minutes ago, james-mc said: Bearing looked ok from what I've seen. Wasn't leaking before i pulled the old HB off. I meant on the tool Link to comment Share on other sites More sharing options...
Comanche SS Posted April 14, 2021 Share Posted April 14, 2021 When installing I just make sure to get it square on there. And some light love taps with a BFH and it goes in far enough to grab the threads. Make sure to grab enough threads...I've pulled some threads before doing it that waySent from my Pixel 5 using Tapatalk Link to comment Share on other sites More sharing options...
Andy in Pa Posted April 14, 2021 Share Posted April 14, 2021 I have swapped out the bolt for a longer one and tightened it to drive the HB on to a point I can safely use the original bolt. Can be tricky, just make very sure its engaged properly on the crank and it should go right on. Link to comment Share on other sites More sharing options...
SVPete Posted April 15, 2021 Share Posted April 15, 2021 Using the proper removal and installation tool...it's easy-peasy. Link to comment Share on other sites More sharing options...
scaleless Posted April 15, 2021 Share Posted April 15, 2021 Not only easy, but theres no risk of stripping out or distorting the threads! Too easy to make that mistake. Link to comment Share on other sites More sharing options...
james-mc Posted April 17, 2021 Author Share Posted April 17, 2021 Installer tool worked perfectly. Now to diagnose this damn overheating issue. Link to comment Share on other sites More sharing options...
