Muncher Posted April 3, 2021 Share Posted April 3, 2021 Now this isn't anything that I'm going to doing anytime soon but i still have some questions about it to see if it'd even work. i plan on re doing all my speakers and radio and adding a sub. one thing that I think would be cool to do is get some marine tower speakers and put them on my roll bar and wire a switch in somehow to turn them off when I don't need them. anything I've seen on doing this is very confusing anyone know how this would be possible to do? Link to comment Share on other sites More sharing options...
jdog Posted April 3, 2021 Share Posted April 3, 2021 @Minuit might know I would see about setting up the speakers on some kind of switch as to not overload the stereo. I'm sure there has to be something out there but wouldn't know what to call it Link to comment Share on other sites More sharing options...
Muncher Posted April 3, 2021 Author Share Posted April 3, 2021 @Minuit might know I would see about setting up the speakers on some kind of switch as to not overload the stereo. I'm sure there has to be something out there but wouldn't know what to call itYea me either Link to comment Share on other sites More sharing options...
Eagle Posted April 4, 2021 Share Posted April 4, 2021 Being basically a troglodyte, I'd be inclined to go back to basics. Do you need the interior speakers to operate at the same time as the exteriors, or will it be one or t'other? If it's either/or, it's simple. Each speaker has two wires. Two double-pole, double-throw toggle switches, one for each side. Link to comment Share on other sites More sharing options...
Pete M Posted April 4, 2021 Share Posted April 4, 2021 start from scratch, don't use factory wires. none of them are made for real power anyways. Link to comment Share on other sites More sharing options...
Minuit Posted April 4, 2021 Share Posted April 4, 2021 No reason you can't switch a set of speakers. The easiest way would be to do as Eagle says - run each pair of speaker wires through a switch that goes to the cab speakers one way and the tower speakers the other way. Just make sure the switch you use is rated to the power output of the amplifier. Link to comment Share on other sites More sharing options...
Muncher Posted April 4, 2021 Author Share Posted April 4, 2021 Being basically a troglodyte, I'd be inclined to go back to basics. Do you need the interior speakers to operate at the same time as the exteriors, or will it be one or t'other? If it's either/or, it's simple. Each speaker has two wires. Two double-pole, double-throw toggle switches, one for each side. It could be a one or another thing. Most Lilkley what I would do Link to comment Share on other sites More sharing options...
ghetdjc320 Posted April 4, 2021 Share Posted April 4, 2021 I use speaker selector switches all the time in home and commercial audio. My question would be how you plan to power them. Will they be running off the head unit or a separate amp? Anything else on that amp? Link to comment Share on other sites More sharing options...
Minuit Posted April 4, 2021 Share Posted April 4, 2021 You will need to pay attention to the impedance of the speakers you're using versus what the amp is rated for (I am assuming and strongly suggesting you're going to be doing this with some kind of amplifier rather than just the headunit alone). If you're going to do this in an either/or way, probably no problem, but if there is any situation where cab and tower speakers are running at the same time, you'll need to be careful. Link to comment Share on other sites More sharing options...
Muncher Posted April 5, 2021 Author Share Posted April 5, 2021 I use speaker selector switches all the time in home and commercial audio. My question would be how you plan to power them. Will they be running off the head unit or a separate amp? Anything else on that amp?Plan on maybe doing a small sub in the truck and I would be using a amplifier Link to comment Share on other sites More sharing options...
