Valve cover.
I've used a '95 XJ VC on my '88 MJ. I also upgraded to the larger CCV Tube and fitting from the latter XJs. I had to cut and splice in tubbing as the RENIX position of the CCV is a bit farther forward. On my '98 XJ, I use a 93-98 ZJ VC. It is aluminum and has the CCV grommets from the 96-01 or even latter 4.0L VC. I use the Felpro VC gasket that is a silicon rubber with a steel reinforcement for the earlier 4.0L. Its about $35-50.
