Preservation or Desecration? The 96/86 Crewmanche Build
On 2/27/2021 at 2:25 PM, Ollie said:
I love it, wish I had the talent to attempt something like that. I always gravitate to "odd Balls" like that at a car show. Sure going to be a head turner.
Having Comanche Fun,
Ollie
Thanks!! And I'm not talented by any means. :rotfl2: I'm just hacking it together with a wing and a prayer. It's not perfect by any means.
  • Replies 86
So I ran out of welding wire the other day... so I moved on to messing with other things till I got more. Redid the headliner, not perfect but it works. I tried to match the cab trim to the Cherokee fronts, but it was a little darker.
  • 4 weeks later...
Pulled the interior back out since it's finally getting warm. Painted the floor and seam sealed everything. Put my sound insulation down, now to put it back together.
Had a friend come over and do bodywork on the roof, not my cup of tea. :laugh:
  • 1 year later...
Small bump. Life has unfortunately gotten in the way the past year.
The main holdup from getting it on the road was a driveshaft.
I wanted a one piece shaft but after talking to numerous shops, I've been steered toward a two-piece.
I've ordered a shaft from a 05 F-150 and will have it shorted and swap joints to make it work hopefully.
Today I got it fired up and did some body work I'd put off. Hope to have it finally going soon!
Got my conversion joints today and put a Jeep Yoke on this Ford Driveshaft and lo-and-behold it actually fit.
Threw up a temporary crossmember just to hold it up there. I'll engineer a drop/open space so I can orient the carrier in the correct position.
While trying to tighten the rear up, I snapped a bolt. Nothing can ever go smoothly. Welded on a nut and got it out thankfully.
Progress in the right direction, hopefully I can keep the momentum going.
