CGCWO Posted April 20, 2021 Author Share Posted April 20, 2021 On 4/18/2021 at 8:36 PM, MiNi Beast said: yeah mine leaks as well. just keep it about 3/4 full cause I'm to lazy to mess with it. Well this turned into an all day job. Got the new o-ring in an then went on to check the wiring on the TPS again since it seemed the engine would stumble occasionally and was very labored under load. Found the wiring issue and decided while I was there to go ahead and delete the C1 connector. Several hours later it looks like this. Also looking more and more like I am going to have to re-build the engine. The more I drive it, it has started to smoke and seems to be getting worse. Jeep Comanche the gift that keeps on giving. Re-building the engine is going to suck without a garage, guess I’ll have to figure out a way to pull the engine and to get it into my little shop. Or bite the bullet and have someone else do it. Link to comment Share on other sites More sharing options...
CGCWO Posted April 21, 2021 Author Share Posted April 21, 2021 So Little Blue isn’t happy with the C1 delete. Well at least the #5 injector isn’t. REMII is giving me a Open injector on #5. Tested the injector plug with my multi meter and get the same readings as on #3 and 4. So I am thinking it might be the injector it’s self. Going to trace the wires to double check my splices on the C1 delete first. Link to comment Share on other sites More sharing options...
Pete M Posted April 22, 2021 Share Posted April 22, 2021 old trucks are... fun. some days are just less fun than others. Link to comment Share on other sites More sharing options...
CGCWO Posted April 22, 2021 Author Share Posted April 22, 2021 12 hours ago, Pete M said: old trucks are... fun. some days are just less fun than others. You hit the nail on the head with that statement. For what it’s worth I replaced the injectors with BOSCH 746 a month or so ago when I was redoing the fuel sending unit and pressure regulator, but I guess I could have one that went bad. Link to comment Share on other sites More sharing options...
CGCWO Posted April 26, 2021 Author Share Posted April 26, 2021 So finally did the compression test, not good. All 6 cylinders have extremely low compression (50-60psi). So I and starting the process to swap in a remanufactured long block and also have the AW4 rebuilt during the swap. Found a reputable local mechanic that is going to do the work for a reasonable amount. Fingers crossed I’ll have a daily driver in a few weeks depending on parts lead times. Link to comment Share on other sites More sharing options...
CGCWO Posted April 29, 2021 Author Share Posted April 29, 2021 While waiting on the new motor and other parts to arrive I finally got the RedRock 2dr JK side steps mounted and installed. Welded in some 2”x6” flat stock to 4 locations on the pinch seam and fabricated braces out of 1”x1” box steal to attach to the frame. Drilled into the step inner bar to attach to the 2x6 tabs that are now welded to the pinch seam. Very solid and hold me jumping up and down. All the attachment points between the truck and side steps are bolted for easy removal if needed. Link to comment Share on other sites More sharing options...
MiNi Beast Posted April 29, 2021 Share Posted April 29, 2021 not bad. turned out as if they were meant to be for the mj Link to comment Share on other sites More sharing options...
JimManche Posted April 30, 2021 Share Posted April 30, 2021 Do you happen to know the name of the paint or color code it is beautiful. I need it in my life I think... Link to comment Share on other sites More sharing options...
CGCWO Posted April 30, 2021 Author Share Posted April 30, 2021 Funny you should ask. I have been trying to decide on paint color. I am not a huge fan of this shade of blue/green. This is from the under hood tag. If I am not mistaken paint code is 6YT. It’s very close to the medium blue metallic. Finally found its new color today in the spray bomb section at Lowe’s (krylon matte ink pen blue). Just a little test on the header panel (unprepped). Reminds me of some of the old Levi Jeep interior fabrics. Link to comment Share on other sites More sharing options...
CGCWO Posted April 30, 2021 Author Share Posted April 30, 2021 6 hours ago, JimManche said: Do you happen to know the name of the paint or color code it is beautiful. I need it in my life I think... see above! Forgot to quote you. Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 30, 2021 Share Posted April 30, 2021 16 minutes ago, CGCWO said: This is from the under hood tag. If I am not mistaken paint code is 6YT. Actually 6YT ought to be your interior trim color and level. Since yours is an 87, it is still AMC so it’s gonna have an AMC color code. It’s one of the two digit codes right next to your interior code. I’m guessing it’s the P3. Would you mind cleaning up the plate a bit? Link to comment Share on other sites More sharing options...
CGCWO Posted April 30, 2021 Author Share Posted April 30, 2021 14 minutes ago, eaglescout526 said: Actually 6YT ought to be your interior trim color and level. Since yours is an 87, it is still AMC so it’s gonna have an AMC color code. It’s one of the two digit codes right next to your interior code. I’m guessing it’s the P3. Would you mind cleaning up the plate a bit? P1 should be it then. Also better pic of plate. Link to comment Share on other sites More sharing options...
CGCWO Posted April 30, 2021 Author Share Posted April 30, 2021 So P1 is classic black, guess my initial suspicions of it being a total repaint are correct. Still think the current color is AJ/medium blue metallic. Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 30, 2021 Share Posted April 30, 2021 I mean that plate looks like a black color but hey the blue looks nice. Not sure who all hunts down a black MJ though. Link to comment Share on other sites More sharing options...
CGCWO Posted May 7, 2021 Author Share Posted May 7, 2021 Scored this H&H shell for Little Blue today. Not Comanche specific, but measurements are 61” x 74.5” should be a good fit and I really like the style. Came off a late 90s SWB Mazda B series truck. Link to comment Share on other sites More sharing options...
Pete M Posted May 15, 2021 Share Posted May 15, 2021 score! let us know how well it fits. Link to comment Share on other sites More sharing options...
MiNi Beast Posted May 15, 2021 Share Posted May 15, 2021 Good head room. Nice. Link to comment Share on other sites More sharing options...
CGCWO Posted May 15, 2021 Author Share Posted May 15, 2021 11 hours ago, Pete M said: score! let us know how well it fits. Will be a couple of weeks before I get it fitted. Just got word (INKYS) new heart will be here mid next week. Going to let a professional do the surgery and rebuild the AW4 while he is doing the heart transplant. Fingers crossed I’ll have a dependable daily driver by the end of the month. Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 15, 2021 Share Posted May 15, 2021 Where’s Pinky, Blinky and Clyde? Link to comment Share on other sites More sharing options...
CGCWO Posted May 16, 2021 Author Share Posted May 16, 2021 20 hours ago, eaglescout526 said: Where’s Pinky, Blinky and Clyde? LOL!!!! Took a while to discover the truck name, settled on INKY after deciding on paint color (Matte Ink Blue). Link to comment Share on other sites More sharing options...
CGCWO Posted May 21, 2021 Author Share Posted May 21, 2021 Picked up the reman longblock today and dropped everything off with the shop that’s doing the swap and trans rebuild. Fingers crossed I’ll be driving it again in a couple weeks with a 4yr unlimited mile warranty on the engine and a 12 month 12k warranty on the transmission. Link to comment Share on other sites More sharing options...
MiNi Beast Posted May 22, 2021 Share Posted May 22, 2021 6 hours ago, CGCWO said: Picked up the reman longblock today and dropped everything off with the shop that’s doing the swap and trans rebuild. Fingers crossed I’ll be driving it again in a couple weeks with a 4yr unlimited mile warranty on the engine and a 12 month 12k warranty on the transmission. 🤞 Link to comment Share on other sites More sharing options...
CGCWO Posted May 25, 2021 Author Share Posted May 25, 2021 Sneak preview of the new color. Link to comment Share on other sites More sharing options...
Pete M Posted June 6, 2021 Share Posted June 6, 2021 dang that's a straight 'gate! Link to comment Share on other sites More sharing options...
CGCWO Posted June 6, 2021 Author Share Posted June 6, 2021 Few more previews of the pieces I’ve have painted. Hoping to get truck back in a week or so and get to work on doors, cab and bed. Will not be a show truck but a decent 20 footer. Link to comment Share on other sites More sharing options...
