Brake booster gasket???
Hey guys recently tore out my old brake booster to get a replacement because we think it's leaking and causing some low vacuum pressure as confirmed by our vacuum tests. Anyone know where to find the gasket that goes in between the firewall and if you can just make one yourself with some gasket maker? I know the gaskets are supposed to be sticky foam but I can't find the gasket anywhere. I have a 1986 2.8l V6. Just replaced it with part %54-74040 from autozone.
