Manche757 Posted November 28, 2020 Posted November 28, 2020 89 MJ, 4.0, Aisin AX15, 92K miles Long story short. I had a leak that mechanics were slow figuring out what was leaking. The culprit was the clutch slave cylinder that was leaking out of the bell housing. I had them replace the clutch plate, the clutch master cylinder along with the clutch slave cylinder. I picked up the truck Tuesday afternoon. The clutch engaged about an inch from the floor. Today, Saturday, when the clutch pedal is fully pressed to the floor, the clutch will NOT fully disengage. It will not go in gear when the motor is running. It has to be started in first or reverse and the engine has to be cut off to change directions. Driving without a clutch is not a big deal once you catch the hang of it although it pretty snarky at stop lights. I understand that there is no adjustment of the clutch pedal on MJs. I just left it at the mechanic’s shop. There are no visible leaks.  Any guess what’s wrong? Â
BeatCJ Posted November 28, 2020 Posted November 28, 2020 The master cylinder needs bled, then the clutch slave needs bled. The shop did it in a hurry, and that just doesn't work. I'm sure you spent enough that it should be right, I would take it back and have them bleed it again. But at almost 60, I may do grumpy better than you.  😂
rokinn Posted November 28, 2020 Posted November 28, 2020 Air in the hydraulics is most likely cause. Â
Manche757 Posted November 28, 2020 Author Posted November 28, 2020 30 minutes ago, BeatCJ said: The master cylinder needs bled, then the clutch slave needs bled. The shop did it in a hurry, and that just doesn't work. I'm sure you spent enough that it should be right, I would take it back and have them bleed it again. But at almost 60, I may do grumpy better than you.  😂 Thanks son. I am thrice young Daeson's age plus a year. Deason is 23.
BeatCJ Posted November 28, 2020 Posted November 28, 2020 Ok, then you can probably handle it. Â I'm used to everyone at work being half my age, or younger. And there is a fair crop on this board that I have been on my SECOND career since before they were born!
eaglescout526 Posted November 28, 2020 Posted November 28, 2020 Yay for math! But I swear I don’t act my age at all. I swear at my generation a lot and disagree with everything they do and how it’s done. That being said, it’s probably also why they didn’t do a great job with your clutch.Â
rokinn Posted November 29, 2020 Posted November 29, 2020 7 hours ago, Manche757 said: Thanks son. I am thrice young Daeson's age plus a year. Deason is 23. +2.Â
Manche757 Posted December 4, 2020 Author Posted December 4, 2020 Took it back to the mechanic. He reverse bled it. Two days later the clutch went out again. Ends up the new slave cylinder was defective so he replaced it with another new one of a different brand.
Torq_Shep Posted December 4, 2020 Posted December 4, 2020 On 11/28/2020 at 7:08 PM, rokinn said: +2. Damn the age spread on this forum is pretty awesome...
Manche757 Posted December 5, 2020 Author Posted December 5, 2020 10 hours ago, Torq_Shep said: Â 17.5 times the square root of 89MJ's age. Post a pic of yourself in the dog getup
Torq_Shep Posted December 5, 2020 Posted December 5, 2020 8 hours ago, Manche757 said: 17.5 times the square root of 89MJ's age. Post a pic of yourself in the dog getup The better half of my twenties are over =PÂ Â This was taken at canyon lands.
eaglescout526 Posted December 5, 2020 Posted December 5, 2020 Most the internal slaves are crap out of the box. I miss the first one I had. Best internal slave, never had to pump the clutch, never had a leak or bleed it when I needed to. It just worked.Â
Manche757 Posted December 5, 2020 Author Posted December 5, 2020 2 hours ago, Torq_Shep said: Â Â This was taken at canyon lands. Torq, you are really fine looking there. Were you really an inner slave when you escaped from the bowls of the Canyon Lands?
Manche757 Posted December 5, 2020 Author Posted December 5, 2020 2 hours ago, eaglescout526 said: Most the internal slaves are crap out of the box. I miss the first one I had. Best internal slave, never had to pump the clutch, never had a leak or bleed it when I needed to. It just worked. I will l Iikely need to have clutch replaced in an 87MJ. What is brand of most trouble free?Â
rokinn Posted December 5, 2020 Posted December 5, 2020 15 minutes ago, Manche757 said: I will l Iikely need to have clutch replaced in an 87MJ. What is brand of most trouble free lies? I've had good luk with luk in other vehicles.Â
Torq_Shep Posted December 5, 2020 Posted December 5, 2020 7 minutes ago, rokinn said: I've had good luk with luk in other vehicles. I was about to say LUK.Â
eaglescout526 Posted December 5, 2020 Posted December 5, 2020 Luk has my vote of confidence as well unless you can find some NOS parts. I know there may be an NOS kit but I think it’s for the 2.5L.Â
cruiser54 Posted December 6, 2020 Posted December 6, 2020 Try this. Pump the clutch pedal to the floor about 50 times. Walk away, if you can, for 20 minutes. Come back and see how it feels. The clutch pedal. Not your leg. Report back.
Manche757 Posted December 6, 2020 Author Posted December 6, 2020 6 hours ago, cruiser54 said: Try this. Pump the clutch pedal to the floor about 50 times. Walk away, if you can, for 20 minutes. Come back and see how it feels. The clutch pedal. Not your leg. Report back. Assuming the highly esteemed gentleman from Prescott is not taking me on a snipe hunting trip, I did as instructed. At 50 pumps, the pedal felt the same as it did on the first pump. After waiting 20 minutes, the pedal felt the same as before. This is on the 89 MJ that has just been worked on with the initial defective slave cylinder that was replaced with another mew slave cylinder a few days later. By now, half of the CC has been out pumping their clutches waiting for your pronouncement.  The 87MJ, 4.0, 201K miles is at the mechanics shop. The clutch on it is probably bad. It has to be snatched into gear and out of gear. It is worse when shifting the first few times after starting. In 5 years, I have put only about 1500 miles on it if that matters.  I would appreciate it if you would have a look at another thread I posted just now about luke warm heat after having just about everything replaced with the cooling system.
cruiser54 Posted December 6, 2020 Posted December 6, 2020 So, how far must you push the pedal down with your hand before you feel resistance?Â
Manche757 Posted December 6, 2020 Author Posted December 6, 2020 46 minutes ago, cruiser54 said: So, how far must you push the pedal down with your hand before you feel resistance? An inch. This is the MJ that was just worked on. Hopefully working ok now
cruiser54 Posted December 6, 2020 Posted December 6, 2020 Okay. Now we're getting somewhere. It's not mushy? Feels like it did before? solid? I'm really not sending you to the submarine races. Honest.Â
Manche757 Posted December 6, 2020 Author Posted December 6, 2020 16 minutes ago, cruiser54 said: Okay. Now we're getting somewhere. It's not mushy? Feels like it did before? solid? I'm really not sending you to the submarine races. Honest. The clutch went out originally. The mechanic replaced the clutch slave cylinder and the clutch master cylinder. It worked ok initially but went out again after two days. That is when I posted. On return to the mechanic, he (reverse) bled it. After a couple of more days it went out again. He replaced the new slave cylinder with a another new slave cylinder of a different brand. Three days later, it is now working ok.
