eaglescout526 Posted November 4, 2020 Share Posted November 4, 2020 Has anyone tried to reupholster their door panels the factory way? Like using staples to hold the material to the door card? I want to give this a try with a door panel fabric I have. I know 3M adhesive is an option but don't want to do that if theres a factory way to do it. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted November 4, 2020 Share Posted November 4, 2020 55 minutes ago, eaglescout526 said: Has anyone tried to reupholster their door panels the factory way? Like using staples to hold the material to the door card? I want to give this a try with a door panel fabric I have. I know 3M adhesive is an option but don't want to do that if theres a factory way to do it. I tried and the staples held fine but the card stock in mine was giving out. Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 4, 2020 Author Share Posted November 4, 2020 I did some research and I might be able to pull this off and start making new door cards and redo door panels. Link to comment Share on other sites More sharing options...
WahooSteeler Posted November 4, 2020 Share Posted November 4, 2020 I had mine done by a shop. They stapled the ends on the back side but rolled and glued the fabric where it meets the top and bottom sections. The door cards are in so-so shape, one definitely shows water damage. I looked in to making new cards on my own, I found the type of heavy cardboard material used for them online. Haven't gone down that path yet. Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 4, 2020 Author Share Posted November 4, 2020 14 minutes ago, WahooSteeler said: I had mine done by a shop. They stapled the ends on the back side but rolled and glued the fabric where it meets the top and bottom sections. The door cards are in so-so shape, one definitely shows water damage. I looked in to making new cards on my own, I found the type of heavy cardboard material used for them online. Haven't gone down that path yet. I found the same ones you probably found and I think I am going to venture down that path and start restoring perfect fabric door panels with new cards. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted November 4, 2020 Share Posted November 4, 2020 I did these , reused some of the door panel foam from a 89 wagoneer and the panel backing I bought from a local upholstery shop . Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 4, 2020 Author Share Posted November 4, 2020 4 hours ago, Strokermjcomanche said: I did these , reused some of the door panel foam from a 89 wagoneer and the panel backing I bought from a local upholstery shop . Perfect. Did you do it the factory way with some staples or something like 3M? I found some of the back board material and I have two door panels that I have no attachment to to give it a shot and make new backs. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted November 5, 2020 Share Posted November 5, 2020 6 hours ago, eaglescout526 said: Perfect. Did you do it the factory way with some staples or something like 3M? I found some of the back board material and I have two door panels that I have no attachment to to give it a shot and make new backs. I used some 3m spray adhesive and some yarn needles with clear thread /line , it's held up fairly well for 4 years Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 5, 2020 Author Share Posted November 5, 2020 14 minutes ago, Strokermjcomanche said: I used some 3m spray adhesive and some yarn needles with clear thread /line , it's held up fairly well for 4 years Nice alright! I think I have a way to try and do it the factory way. I will have to report on my status when I get what I need to pull this off. Link to comment Share on other sites More sharing options...
WahooSteeler Posted November 5, 2020 Share Posted November 5, 2020 Eagle, I also looked in to a spray on coating that would add some level of waterproofing to the door card. I recall finding a few products that seemed like they would work, I didn't save any of the info though. Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 5, 2020 Author Share Posted November 5, 2020 Just now, WahooSteeler said: Eagle, I also looked in to a spray on coating that would add some level of waterproofing to the door card. I recall finding a few products that seemed like they would work, I didn't save any of the info though. Thats a smart idea. But also reminds me of when I went to Alaska as a high adventure camp and one of the scouts that also went up claimed he used 7 cans of water proof on all his equipment and it still failed lol. But I am sure water proofing improved since 2010 and will give it a shot. Link to comment Share on other sites More sharing options...
Pete M Posted November 5, 2020 Share Posted November 5, 2020 I mean... does the door card need to be made of cardboard? Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 5, 2020 Author Share Posted November 5, 2020 1 minute ago, Pete M said: I mean... does the door card need to be made of cardboard? No...but I watched a video of a guy repairing his SJ door card with some sort of pressed PVC board, looked like it was going well but nothing more came of it. It would be nice though(which I plan on doing) to replace the bad door cards with new ones on panels that still have really good material. Link to comment Share on other sites More sharing options...
Pete M Posted November 5, 2020 Share Posted November 5, 2020 although in all honesty, if you properly replace the plastic barrier (and don't live in the stupid-humid states) the cardboard should be fine. Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 5, 2020 Author Share Posted November 5, 2020 Very true, but I do not know if anyone makes a cut to fit water barrier, at least not that I have looked into it. Link to comment Share on other sites More sharing options...
AZJeff Posted November 5, 2020 Share Posted November 5, 2020 The door “cardboard” can be replaced by hardboard commonly called “Masonite” that is found at lumber yards. Replacement “watershield” material can be fabricated from 3mil thick clear poly sheeting, and attached using the special “sticky caulk” that comes in rolls and is available on Amazon. Using the poly and the special caulk allows the shield to be removed/reused without damage. That’s an important feature for owners of older Jeep’s😆 Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 6, 2020 Author Share Posted November 6, 2020 Yeah that’s what I’m gonna start doing is making the backs with exceptional panels. I’m gonna order some backs today and I already have a couple panels to experiment with. Link to comment Share on other sites More sharing options...
Rad_Comanche Posted April 13, 2021 Share Posted April 13, 2021 Have you made any progress on this? I was removing my door panel today to replace my weather stripping, and my driver side is warped, ripped, does not hold all the trip clips. Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 13, 2021 Author Share Posted April 13, 2021 29 minutes ago, Rad_Comanche said: Have you made any progress on this? I was removing my door panel today to replace my weather stripping, and my driver side is warped, ripped, does not hold all the trip clips. To a degree. Life got in the way of doing these. I managed to get one cut but the shape needs to be trimmed a little. I need to take the other one apart since it has a great back and use that as the template. But needless to say it is straight forward. The staple situation though on the other hand, I never figured out. Link to comment Share on other sites More sharing options...
