Top C Posted October 28, 2020 Share Posted October 28, 2020 (edited) Ok so I'm sure I'm in the right section but I wanted to register my MJ with this site. I don't much about the history of it except I bought it from a Co-worker The Vin number is 1JTMP631XHT189821 1987 JEEP COMANCHE AUTOMATIC TRANSMISSION FOUR WHEEL DRIVE 4.0 ENGINE This is all the information I can provide at the moment. Please if I'm wrong area could you let me know I will do what to move it. Thanks Mike Edited November 8, 2021 by Top C add picture Link to comment Share on other sites More sharing options...
89 MJ Posted October 28, 2020 Share Posted October 28, 2020 20 minutes ago, TOP said: Ok so I'm sure I'm in the right section but I wanted to register my MJ with this site. I don't much about the history of it except I bought it from a Co-worker The Vin number is 1JTMP631XHT189821 1987 JEEP COMANCHE AUTOMATIC TRANSMISSION FOUR WHEEL DRIVE 4.0 ENGINE This is all the information I can provide at the moment. Please if I'm wrong area could you let me know I will do what to move it. Thanks Mike Yes u will need to go to the 1987 section and create a new topic there. Have your VIN as the title. Link to comment Share on other sites More sharing options...
Pete M Posted October 28, 2020 Share Posted October 28, 2020 moved it for ya. Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 28, 2020 Share Posted October 28, 2020 *A6 Seats - Vinyl High Back Bucket -H9 3LQ APA MONOTONE PAINT PACKAGE BCQ Battery - 750 Amp Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DGW Transmission - 4-Spd. Automatic ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NHM AUTO SPEED CONTROL PYC QYC RAF Radio - AM/FM Cassette SBA POWER STEERING TBB CONVENTIONAL SPARE TIRE TBL TIRE CARRIER - INSIDE WJN 15" Aluminum Wheels Build date 6/23/87 Body code JL61. I was waiting for it to be moved. Didnt want to clutter something up. Link to comment Share on other sites More sharing options...
Top C Posted October 28, 2020 Author Share Posted October 28, 2020 Bought in Spotsylvania Co Va. over two years ago. Updated the computer to 1990. Replaced the fuel injectors to the 4 point injectors. New water pump and updated the cooling system by removing the Heat vacuum valve and adding a coolant reservoir. Put a 3" lift on it. Moved the Vacuum reservoir from the from bumper to the fire wall. Replace the instrument cluster to full gauge cluster. The vehicle aside from the paint is in very good condition. Plan on having it painted next spring. Has 4.0 engine Automatic Transmission with 4 wheel drive. Link to comment Share on other sites More sharing options...
jdog Posted October 28, 2020 Share Posted October 28, 2020 @TOP Link to comment Share on other sites More sharing options...
Top C Posted October 29, 2020 Author Share Posted October 29, 2020 So this is the only information on it 88 4.0 4x4 ? Thanks Mike Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 29, 2020 Share Posted October 29, 2020 Applicable to only the VIN you have. Link to comment Share on other sites More sharing options...
Pete M Posted October 29, 2020 Share Posted October 29, 2020 8 minutes ago, TOP said: So this is the only information on it 88 4.0 4x4 ? Thanks Mike a lot of the early year's info was lost in a basement flood before they could be inserted into Chrysler's computers. the list of codes should be much longer. but there's still hope! your truck's original paper copy might be still in the truck they are sometimes behind the door panel, behind the rear carpet wall, under a seat or even up under the dash on the pass side. Link to comment Share on other sites More sharing options...
Top C Posted October 29, 2020 Author Share Posted October 29, 2020 Thank you for the information I've seen what you mean about the paper work being behind stuff. I will check there this weekend. Link to comment Share on other sites More sharing options...
89 MJ Posted October 29, 2020 Share Posted October 29, 2020 6 hours ago, TOP said: Thank you for the information I've seen what you mean about the paper work being behind stuff. I will check there this weekend. Let's see some pictures of the truck! Link to comment Share on other sites More sharing options...
fiatslug87 Posted November 2, 2020 Share Posted November 2, 2020 Build sheet please. Link to comment Share on other sites More sharing options...
89 MJ Posted November 2, 2020 Share Posted November 2, 2020 1 minute ago, fiatslug87 said: Build sheet please. Already been taken care of. Could these threads be merged though? Link to comment Share on other sites More sharing options...
fiatslug87 Posted November 2, 2020 Share Posted November 2, 2020 On 10/28/2020 at 6:53 PM, TOP said: So this is the only information on it 88 4.0 4x4 ? Thanks Mike It's an 87, base model, 4.0L, 4x4, coulmn shift auto., paint is Grenadine Metallic. Link to comment Share on other sites More sharing options...
fiatslug87 Posted November 2, 2020 Share Posted November 2, 2020 @Pete M can you delete this double post? Thanks. Link to comment Share on other sites More sharing options...
Pete M Posted November 3, 2020 Share Posted November 3, 2020 merged Link to comment Share on other sites More sharing options...
jdog Posted January 31, 2021 Share Posted January 31, 2021 Selling Dealer: HARRY GREEN CHEVROLET INC Clarksburg, WV Link to comment Share on other sites More sharing options...
