Top C
    Fredericksburg,Va
  • Interests
    Jeeps & Ham Radio
2688 profile views
Top C's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. Thanks and I assume looking at the replacement this is one piece which takes care of the inside and outside? And one question how do you put them in? thanks Mike
  2. Where can I buy the plastic window rails pieces that go on either side of door windows on my Jeep comanche. Mine breaking apart from age. My windows roll up and down ok but I know these strips keep the window alined. Thanks for your help. Mike
  3. Ok I will check that today and hopefully that is what happend. It’s been gradually moving all the way to the left. I’m sorry I didn't mention that part.
  4. The dash indicator broke. Is there an after market replacement or maybe a Ford/Chevy type that would work? Thanks
  5. Is there a replace for the plastic clip that holds the shifter cable to transmission? Thanks Mike
  6. Has anyone determined what 02 sensor is go replacement for a Renix 1987 4.0 engine? Thanks Mike
  7. Update got the new CPS installed this evening and engine started right up. Thanks to all the comments and suggestions. One thing I found very useful was a swivel socket my bolts were 7/16 and my friend had one. 10 mins tops to reinstall with it. If you have an automatic you need to unbolt the bracket holding the shifter cable makes that much easier. Thanks again keep on Jeepin!
  8. Okay so I test everything that is check for 12vdc at the larger of the two ports on passenger side and got 12v. Then went to the ECU and got 12vdc there using the cable ground, so I was checking both positive and negative at cable connector. Then I check for 05 ac at the EUC nothing (engine cracking). Then I went the CPS and check there for .05 Vac nothing there. So I pull the CPS sensor and will replace it. It will probably be Thursday afternoon before I can get to it. Those bolts holding that sensor are a real pain to get to. Luckily they were not rust in. I think I'm going to get one bolt in on the CPS, get the engine start and drive it to my friends garage have them put that second bolt in. My luck I'd drop it through the slot into bellhousing. Thanks for your help I'll report back after I get it running. Mike
  9. Ok thanks that clears up the confusion i had about this. I will give it try tomorrow evening and let you know I find.
  10. No I have not retested the cps. I heard different options about this. Is .02 VAC the minimum you want to see on the CPS? Does the engine need to be cranking to measure the voltage? Thanks for your reply Mike
  11. I hope I'm in the right area to to ask this question. My 87 MJ 4.0 has no spark. I did the following checks Took the center wire off the distributor cap and put spark plug on it and no spark Cleaned the C101 connector no spark Unplugged the CPS cable and reconnected it no spark Unplugged and reconnect both connectors on the coil no spark Check the relays all are good So my next thought is replacing the CPS Sensor is Napa the best place to purchase? Should I next look at the Coil and the unit the coil sits on? The last item would be ECU I replace the original 5 yrs ago with a 90 ECU but kept the original if all else fails I will put that back in. Since I know this is an electrical problem and I've isolated the distributor from the problem is there anything else I'm missing should be check that would cause a no spark condition? Thanks Mike
  12. Key parts do you have a link for them?
  13. Okay thank you for the info.
  14. I need to replace the floor pan on drivers side of 87 MJ. I need to know a good quality place to purchase a replacement? I google it and I came up C2C is a good quality pan? Also I want to seal the joints what is the best sealant for this job? Thanks Mike
