Muncher Posted October 11, 2020 Share Posted October 11, 2020 Very descriptive title but I just found this in my door is this part of the latch or something random. Link to comment Share on other sites More sharing options...
The86manche Posted October 11, 2020 Share Posted October 11, 2020 Thats part of your door catch that holds your door open. Would bolt to the A pillar and side of the door Link to comment Share on other sites More sharing options...
Minuit Posted October 11, 2020 Share Posted October 11, 2020 The proper name for it is the "door check" The 97+ versions are an upgrade. Link to comment Share on other sites More sharing options...
MiNi Beast Posted October 11, 2020 Share Posted October 11, 2020 its what keeps the door from being slammed opened from the wind and what not and just added weight. scrap it. Link to comment Share on other sites More sharing options...
Muncher Posted October 11, 2020 Author Share Posted October 11, 2020 1 hour ago, MiNi Beast said: its what keeps the door from being slammed opened from the wind and what not and just added weight. scrap it. It was just chilling at the bottom of my door anyways not attached to anything Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 11, 2020 Share Posted October 11, 2020 Which probably means your door check is busted and the door opens wayy father than it should. Link to comment Share on other sites More sharing options...
jdog Posted October 11, 2020 Share Posted October 11, 2020 or somebody was lazy and dropped it Link to comment Share on other sites More sharing options...
Muncher Posted October 12, 2020 Author Share Posted October 12, 2020 2 hours ago, eaglescout526 said: Which probably means your door check is busted and the door opens wayy father than it should. Haven't really checked but when ever it swings open because of wind I usually just grab it but I haven't seen it swing super far out Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 12, 2020 Share Posted October 12, 2020 Yup! Thats a good indicator that the door check has been disintegrated into pieces like the one you found. Link to comment Share on other sites More sharing options...
MiNi Beast Posted October 12, 2020 Share Posted October 12, 2020 i removed mine when i modded the hinges to remove the doors. fyi- idc about body lines. Link to comment Share on other sites More sharing options...
