Just wanted to post here about my experience with the FF Dynamics triple 10 fan kit. I’ve had the kit for 2 years. The fans work well but are a bit on the noisy side. They are sealed and have a lifetime warranty. Their specs show better than most spal fans. Current draw is supposed to be 5a each but that doesn’t tell you at what voltage. They include an “adjustable” fan controller that has some serious shortcomings though. First of all, it only handles 30a and these fans pull right at that on startup. Second, the controller only has a single on/off temp. So when temp is close to the startup temp it will cycle on/off frequently and really puts a heavy load on the electrical. My controller fuse holder (which is only 14awg) melted A few months back and now the whole controller is shot. I’ll be replacing it with a painless 60a controller with a 10degree sweep between on and off positions. The FF dynamics controller is junk and there customer support seems to never really understand the issue so it will likely continue. Perhaps this belongs in the pub section but hopefully I can save someone the trouble of buying and using that controller.
I heard similar stories and decided to just do my own thing. 1 pusher and stock puller run same time keeps my temps handled. Thanks for the follow-up though,  much appreciated. 👍
@EUREKA That does look similar. I believe dirt bound off-road makes a triple 10 shroud that you can install your own fans on. Perhaps their shroud and some tried and true Spal fans and quality controller that can handle the load should work well. I am a bit dubious in the FF dynamics fan output claim. I have a feeling they are estimating the current draw and cfm at  14.5v or so under ideal circumstances.
Also, Mishimoto has a setup. I have the Dirtbound part. I have not bought the Spal fans yet. I did buy a Spal 10" fan that is 1100 CFM. It does not fit the Dirtbound frame. I'll be looking into putting 3 of them with out a frame down the line. They are thicker, so there might not be space to clear the A'C bracket pulley.
I just finished installing this set up and it works wonders. Truck gets up to 210 and when I turn on the fans (5 min later) its in the 180 range
What size pusher did you run? Looking for something I could put in front of my condenser
I ran a 10" fan. wired both fans(pusher and factor puller) to a 50amp realy, to a manual switch to turn on and off when I want.
I don't have a condenser but have the trans cooler in same place. Pusher is mounted on front side and pushes air through rad and cooler and the stock pulls air through the engine bay side. With this setup I have found it nice as when have no natural Air flow from driving i can still move air on the trail. Also mines set up with switch to turn on or off as needed. Hit a water hole i kill them, driving down highway i kill them, not that i need to as they shut off as needed. And with that I can leave it switched on once parked on trail and they can still work as needed.
Also keeping in mind that I do have hood vents with my setup as was my first attempt at getting temps down. Finally got a 10" pusher fan and have been happy ever since. Granted I'm in MI and not in the California desert.
Biggest concern some argue is a good shroud to contain and direct the air flow. Fan shrouds make it more efficient for sure. I like the triple kits just not the price. And shop around as i have seen my same fan for half as much and double what I paid. I paid 60 new at local 4x4 shop. And I didn't want to pay that either but needed to be done that weekend for a trip plus I was installing a new radiator at same time so made sense to do it then.
42 minutes ago, MiNi Beast said:
And fyi my fan can be pusher or puller just a matter of flipping the fins around.
the fins are removable?
but if I pull off the fan assembly, then flip it over and reinstall... don't the blades still point the same way as before?  I must be tired...
this is why they give you instructions 🤣
I think you both are tired lol. Flipping a fan blade assembly will not change the direction of the air flow. You should be able to simply reverse polarity on the fan motor. Unless you can change the pitch of the blades like a helicopter.
