ghetdjc320 Posted August 23, 2020 Share Posted August 23, 2020 Oh, and strokedjeep.com does awesome work with throttle bodies. I’ve bought 4 from him over the years Link to comment Share on other sites More sharing options...
89 MJ Posted August 23, 2020 Author Share Posted August 23, 2020 On 8/23/2020 at 11:22 PM, ghetdjc320 said: Oh, and strokedjeep.com does awesome work with throttle bodies. I’ve bought 4 from him over the years Expand Thanks! Link to comment Share on other sites More sharing options...
89 MJ Posted August 23, 2020 Author Share Posted August 23, 2020 On 8/23/2020 at 11:06 PM, Ωhm said: Renix Engine Monitor (REM) Expand Thank. I’m looking into one now. Link to comment Share on other sites More sharing options...
Swampy Posted August 24, 2020 Share Posted August 24, 2020 Just to chime in which 4 hole injectors fit the 4.0? Ones off a mustang I have heard or the ones from an explorer? Link to comment Share on other sites More sharing options...
derf Posted August 24, 2020 Share Posted August 24, 2020 On 8/23/2020 at 3:50 PM, Eagle said: Thanks for making me feel my age. I'm old enough to remember the days when a zero to 60 time of 10 seconds flat was considered to be FAST! That was once sort of the automotive equivalent of a 4-minute mile. Expand I learned to drive in a 1978 Olds with the 5.7 diesel. 0-60 was pretty close to the 1/4 mile time. (19.8 0-60 with a 22.6 1/4 mile). Looking back, having a slow car like that probably saved my life. Link to comment Share on other sites More sharing options...
Pete M Posted August 24, 2020 Share Posted August 24, 2020 On 8/24/2020 at 2:26 PM, Swampy said: Just to chime in which 4 hole injectors fit the 4.0? Ones off a mustang I have heard or the ones from an explorer? Expand I don't know for sure, but I'd wager that both will work. there are a plethora of injectors out there that will have 4 hole but not too much of a flow rate (neons and volvos come to mind). for some reason fuel injectors are remarkably interchangeable (outer dimensions at least) across time and space and brands. (meanwhile I had to go buy a 7mm and 11mm allen wrenches to do the brake pads on the Durango and when I finally need to do the rotors, I gotta buy a giant reverse torx! ) Link to comment Share on other sites More sharing options...
Limeyjeeper Posted August 24, 2020 Share Posted August 24, 2020 On 8/24/2020 at 2:26 PM, Swampy said: Just to chime in which 4 hole injectors fit the 4.0? Ones off a mustang I have heard or the ones from an explorer? Expand You really need 21lb injectors. The Mustang injectors are 24lb. They are 4 hole. Here is some info on injectors courtesy of Dino Savva. Injectors Some of those specs that are hard to find in any workshop manual. The following is a list of the injectors used on the 4.0L since 1987 along with their rated static flow:Model Year, ...Part #, ...........Colour, .....Fuel Pressure, ...Static Flow, '87-'90, ........53003956, .........Dark Tan,.......39psi, .................21.0lb/hr '91-'93, ........33007127, .........Brown, ..........39psi, .................21.0lb/hr '94-'95, ........53030343, .........Tan, ..............39psi, .................21.0lb/hr '96-'98, ........53030778, .........Grey, ............49psi, .................23.2lb/hr '99-'04, ........04854181, .........Blue tip, ........49psi, .................22.5lb/hr '05-'06, ........53013690AA, ....Brown tip, .....58psi, .................25.4lb/hr The injector flow rate varies as the square root of the pressure drop across the injector. The stock '91-'95 4.0 injectors are rated at 22lb/hr @ 43psi fuel pressure, so at 39psi they flow ( sq. rt.(39/43) x 22.0 = 21.0 ). For stock/modified 4.0 engines or stroker build-ups the following injectors can be installed. The flow rates are: Ford Motorsport 19.0lb/hr @ 39psi (Part no. FMS-M9593-C302) Ford Motorsport 24.0lb/hr @ 39psi (Part no. FMS-M9593-A302) Ford Motorsport 30.0lb/hr @ 39psi (Part no. FMS-M9593-B302) Bosch 0280155712 19.4lb/hr @ 43.5psi Bosch 0280155703 22.7lb/hr @ 43.5psi Bosch 0280155715 23.7lb/hr @ 43.5psi Bosch 0280155849 24.5lb/hr @ 43.5psi (same as Ford XF1E-A5B) Bosch 0280155784 26.3lb/hr @ 43.5psi Chevy LT1 24.0lb/hr @ 43.5psi (Part no. 17124248) Chevy LT4 28.0lb/hr @ 43.5psi (Part no. 17124251) '98 Chevy LS1 25.2lb/hr @ 58.0psi (Part no. 12533952) '99-'00 Chevy LS1 26.2lb/hr @ 58.0psi (Part no. 12456154) '01-'02 Chevy LS1/LS6 28.6lb/hr @ 58.0psi (Part no. 12482704) Accel 19.2lb/hr @ 44.1psi (ACC-150119) Accel 21.1lb/hr @ 44.1psi (ACC-150121) Accel 24.4lb/hr @ 44.1psi (ACC-150124) Accel 25.6lb/hr @ 44.1psi (ACC-150126) Accel 29.4lb/hr @ 44.1psi (ACC-150130) The '95 Jeep 5.2 ZJ/Dodge 5.9 injectors (Part no. 53030262) are rated to flow 24.6lb/hr at 39psi. The selection of injector size will depend on the estimated horsepower output, brake specific fuel consumption BSFC (assume 0.5), no. of cylinders, and the injector duty cycle (assume 80% or 0.8). The formula is: Injector size (lb/hr) = (horsepower x 0.5)/(no.of cylinders x 0.8) Link to comment Share on other sites More sharing options...
Swampy Posted August 24, 2020 Share Posted August 24, 2020 Thanks for the info. I have a 96 HO motor so I might run the mustang injectors Link to comment Share on other sites More sharing options...
Limeyjeeper Posted August 24, 2020 Share Posted August 24, 2020 The HO PCM can dial back the injector pulse rate pretty well. I run Ford Motorsport 24lb Cobra injectors (Blue body) in my Stroker and they work fine. The Bosch injectors work well too. I have used https://www.fiveomotorsport.com many times over the years. They have a great quality product. Link to comment Share on other sites More sharing options...
Pete M Posted August 24, 2020 Share Posted August 24, 2020 On 8/24/2020 at 3:09 PM, Swampy said: Thanks for the info. I have a 96 HO motor so I might run the mustang injectors Expand not according to your signature. Link to comment Share on other sites More sharing options...
Swampy Posted August 25, 2020 Share Posted August 25, 2020 On 8/24/2020 at 5:03 PM, Pete M said: not according to your signature. Expand I was planning on updating it officialy when the truck is running Link to comment Share on other sites More sharing options...
