Piilgrim82 Posted August 8, 2020 Share Posted August 8, 2020 Hi guys, Since I bought my MJ a couple years ago the cruise control hasn't worked. I have a long road trip coming up where it would really save my knees, so I'm hoping to get it working. Took a peak at it yesterday and there appears to be vacuum pressure as when I pulled the small vacuum line that runs out of the canister it feeds into (not the one in the bumper) I heard the pressure release. So I decided to take a look at the wiring under the dash and right away noticed a stray broken pink wire, which appears to connect to the brake switch..here's a photo if anyone can confirm that's where it goes. Aside from that, can anyone give some advice on how to troubleshoot this? I try and fix most things by youtube videos but couldn't find much in this. Link to comment Share on other sites More sharing options...
Piilgrim82 Posted August 8, 2020 Author Share Posted August 8, 2020 Here's the photo...hopefully you can view it, taken with my iphone. IMG_4024.HEIC Link to comment Share on other sites More sharing options...
Dzimm Posted August 8, 2020 Share Posted August 8, 2020 I'm assuming you are using an iPhone to upload the picture? What you've attached is in a high efficiency file format (.heic) that iPhones now use by default that won't open natively for anyone on an Android phone or windows computer. I can't get on the computer right now so I can't convert and reupload, can you or someone else please convert it and reupload so we can all see the image? Link to comment Share on other sites More sharing options...
schardein Posted August 8, 2020 Share Posted August 8, 2020 Here is the image Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 8, 2020 Share Posted August 8, 2020 So your brake switch should have two sets of prongs. One for the main harness and one for cruise control. I think the pink wire is for the cruise control side, as long as you still have the old Renix set up. As Dzimm said about the photo thing, if you are using iphone, how are you uploading your pictures? Usually i don't have an issue when I'm actually looking at CC under Safari. Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 8, 2020 Share Posted August 8, 2020 Now that the photo has been loaded, yes thats entirely for cruise control and is needed to operate. Link to comment Share on other sites More sharing options...
Piilgrim82 Posted August 8, 2020 Author Share Posted August 8, 2020 Sorry about the photo trouble fellas, I'll try uploading directly from my cell on safari next time! (I've been uploading them using my computer.) I tried connecting it and still didn't have any luck, any advice where to check next? Thanks for the help! Link to comment Share on other sites More sharing options...
jdog Posted August 8, 2020 Share Posted August 8, 2020 How is the fuse? Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 8, 2020 Share Posted August 8, 2020 If youre ready for this and want cruise to work, we are about to dive into a whole world of fun! Link to comment Share on other sites More sharing options...
SoCalManche Posted August 8, 2020 Share Posted August 8, 2020 3 minutes ago, eaglescout526 said: If youre ready for this and want cruise to work, we are about to dive into a whole world of fun! Eagle and I have a massive text exchange we could probably dig up. It has just about every scenario of potential flaws your CC system may or may not have. Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 8, 2020 Share Posted August 8, 2020 2 minutes ago, SoCalManche said: Eagle and I have a massive text exchange we could probably dig up. It has just about every scenario of potential flaws your CC system may or may not have. Lol. Yet we still can't quite get yours to work as it should despite every dang test I can think of. Link to comment Share on other sites More sharing options...
SoCalManche Posted August 8, 2020 Share Posted August 8, 2020 Just now, eaglescout526 said: Lol. Yet we still can't quite get yours to work as it should despite every dang test I can think of. Let's not bring that negativity to @Piilgrim82's MJ. I have faith his issue will be resolved... Lol. Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 8, 2020 Share Posted August 8, 2020 1 minute ago, SoCalManche said: Let's not bring that negativity to @Piilgrim82's MJ. I have faith his issue will be resolved... Lol. Oh yeah it will be, Just Dr. Cruise gives your system prognosis as a "special case". Link to comment Share on other sites More sharing options...
SoCalManche Posted August 8, 2020 Share Posted August 8, 2020 1 minute ago, eaglescout526 said: Oh yeah it will be, Just Dr. Cruise gives your system prognosis as a "special case". Nothing new with Project Unicorn. Link to comment Share on other sites More sharing options...
87MJTIM Posted August 8, 2020 Share Posted August 8, 2020 Fix the pink wire to that connector. Attach the connector to the brake switch on the brake pedal. Match pink to pink. As for testing your cruise control, there is a device that test the wiring and vacuum unit, AM PC-1-R. However, the 88 Electric Manual has steps you can perform that will test the wiring with a DVOM. Download the 88 Manual in the DIY section on CC and perform those tests. My experience, though, is it is the yellow controller box that has gone bad. You will need to search for a replacement, since you cannot purchase new. Link to comment Share on other sites More sharing options...
Piilgrim82 Posted August 9, 2020 Author Share Posted August 9, 2020 On 8/7/2020 at 10:22 PM, eaglescout526 said: If youre ready for this and want cruise to work, we are about to dive into a whole world of fun! Hahaha it sure sounds like it! I’ll give @87MJTIM’s advice a try before I pull you all into this any further :) Oh and yes, @jdog fuse is good! Link to comment Share on other sites More sharing options...
