watchamakalit Posted July 13, 2020 Share Posted July 13, 2020 Ok you guys know the drill.... What is this one for? And what has happened here with the red wire? P.O. work or is this a factory solder joint? It was only wrapped with electrical tape so I have a feeling it is PO. My truck does have old brackets on the front bumper for what I assume were driving lights. I have yet to find any evidence where someone wired them in. Did I just find the remains? My truck did not have factory fog lights. Forgot the pic. Link to comment Share on other sites More sharing options...
87MJTIM Posted July 13, 2020 Share Posted July 13, 2020 Radiator coolant temperature switch? Link to comment Share on other sites More sharing options...
watchamakalit Posted July 15, 2020 Author Share Posted July 15, 2020 Bump. Any other thoughts? Wondering about the red wire splice also. Link to comment Share on other sites More sharing options...
Pete M Posted July 15, 2020 Share Posted July 15, 2020 definitely the rad temp switch. do you have a fuel pump resistor? Link to comment Share on other sites More sharing options...
Ωhm Posted July 15, 2020 Share Posted July 15, 2020 On 7/13/2020 at 7:48 AM, 87MJTIM said: Radiator coolant temperature switch? Color codes seem to be correct for that connector. YEL & GRY w/TR 20 hours ago, watchamakalit said: Wondering about the red wire splice also. Do you have a factory Cooling Fan Relay? Link to comment Share on other sites More sharing options...
watchamakalit Posted July 15, 2020 Author Share Posted July 15, 2020 I still have my ballast resistor so I know that's not it. Yes I have a cooling fan relay still intact. Link to comment Share on other sites More sharing options...
Ωhm Posted July 15, 2020 Share Posted July 15, 2020 Since you have a Radiator Temperature Switch (RTS) connector that goes no where, is the Cooling Fan ON with the KEY ON? Is vehicle equipped with AC? Link to comment Share on other sites More sharing options...
watchamakalit Posted July 15, 2020 Author Share Posted July 15, 2020 I do have factory ac. And I don't think ive ever heard my electric fan come on. Lol Link to comment Share on other sites More sharing options...
jdog Posted July 15, 2020 Share Posted July 15, 2020 red wire is supposed to be that way, just supposed to have a cover over it Link to comment Share on other sites More sharing options...
Ωhm Posted July 15, 2020 Share Posted July 15, 2020 With AC selected and when the compressor clutch engages, does the Cooling Fan also engage? Link to comment Share on other sites More sharing options...
Ωhm Posted July 15, 2020 Share Posted July 15, 2020 29 minutes ago, jdog said: red wire is supposed to be that way, just supposed to have a cover over it You've seen this before? That's interesting and well worth knowing. Link to comment Share on other sites More sharing options...
jdog Posted July 15, 2020 Share Posted July 15, 2020 This is the wiring harness for a/c on mine, note the red wire. altho I can't say it came from the factory that way, the vehicle i pulled it from was pretty stock and didn't seem like the p/o screwed with things Link to comment Share on other sites More sharing options...
Ωhm Posted July 15, 2020 Share Posted July 15, 2020 Never doubt a "good eye". Link to comment Share on other sites More sharing options...
watchamakalit Posted July 15, 2020 Author Share Posted July 15, 2020 Well thats good to know. I'll resolder and heat shrink it. As far as the fan, I don't know if it runs with the ac on or not. The ac has no charge in it so I don't currently use it. I'll have to check on the fan tomorrow. Link to comment Share on other sites More sharing options...
jdog Posted July 15, 2020 Share Posted July 15, 2020 easy way would be jump the two connectors on the open plug and turn the key on, the fan should kick on Link to comment Share on other sites More sharing options...
Minuit Posted July 16, 2020 Share Posted July 16, 2020 Probably a diode pack in there. Link to comment Share on other sites More sharing options...
