Model 35. (Dana 35) should have 3.07 with a 5 speed. The tag is unreadable in the picture.
Automatic trucks normally came with 3.55/3.54
ratio can be determined by spinning 1 tire around twice and counting the times the driveshaft spins.  :L:  about 3 times is a 3.07
Jack up one tire, make a mark on the tire and fender (chalk works well), make another marker on the driveshaft and pinion snout. Then rotate the tire through two full revolutions counting how many times the driveshaft spins around. This will give you a rough ratio. The only options (unless aftermarket work has been done) are 3.07, 3.55, and 4.10. Maybe 3.73 was an option but I personally have not come across that one.
Or pull the cover and count teeth. This will give you the exact answer.
1 hour ago, Straatmann said:
I’ll have to jack it up and check it, I added the vin to the registry, but their was no info on the gear ratio
Once it is decoded, they will get your info.
the ratio won't always come up since a lot of AMC info was lost before it could be inserted into Chrysler's computers. :(   But I can say with confidence that it came with the 3.08s from the factory. :L:  that doesn't mean it still has 'em though.  anything can happen in 3 decades.
