ComancheMadness Posted May 22, 2020 Share Posted May 22, 2020 I was wondering if a 1972 blazer/jimmy rear dana 44 will work and fit on my 88 jeep comanche 2wd Link to comment Share on other sites More sharing options...
Ls2xjcomanche Posted May 22, 2020 Share Posted May 22, 2020 It might but would definitely take some fabrication. Not 100% sure, but I don’t think the bolt pattern would match either unless you swapped the front axle as well. Other rear options could be a MJ or XJ 44, but they’re pretty hard to come by. Ford 8.8 axle is another option (same bolt pattern, disc brakes, just slightly narrower). Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 22, 2020 Share Posted May 22, 2020 To add on to the list of axles the Honda passport and Isuzu rodeo from the 90’s have disc D44’s Link to comment Share on other sites More sharing options...
ghetdjc320 Posted May 22, 2020 Share Posted May 22, 2020 I wrote a thread about the Isuzu/passport d44 axle swap and have a ton of info on them if you need any. I’d not recommend an 8.8 unless you already own it Link to comment Share on other sites More sharing options...
Ls2xjcomanche Posted May 23, 2020 Share Posted May 23, 2020 Here’s an article that might help you narrow down your options. Good luck! https://www.offroadxtreme.com/news/dana-35-vs-dana-44-whats-the-difference/ Link to comment Share on other sites More sharing options...
ghetdjc320 Posted May 23, 2020 Share Posted May 23, 2020 2 hours ago, Ls2xjcomanche said: Here’s an article that might help you narrow down your options. Good luck! https://www.offroadxtreme.com/news/dana-35-vs-dana-44-whats-the-difference/ The Dana 44 comes in multiple varieties and that article only shows the TJ/XJ Dana 44. First off the ZJ V8 d44 is an aluminum housing setup similar to the corvette version. The 98+ rodeo/passport d44 has d60 size pinion and an 8.9” ring gear. Quite a bit beefier than the 8.8. Thicker axle tubes as well. I think a lot of people think that Dana made a whole new axle for the JK but the HD gear set came out in 98 or maybe even earlier. The rodeo/passport axles also have disk brake options and most are 4.10 and 4.88 but you find plenty of different ratios depending on the vehicle. The Dana 44 was even used with 2wd 4cyl rodeo/passports. By the way, the dana 35 is still in use today in the JT and JL. The 07 JK also had a d35 depending on the build date. However the new d35’s are quite a bit stronger than the old ones in our trucks. The d44 in the rodeo/passport is a super good option and the only major drawback is the whee bolt pattern which can be addressed a number of ways. They are very cheap to pickup and super abundant in most places. Very stout axles that have been good on even 37’s without any major upgrades. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted May 23, 2020 Share Posted May 23, 2020 Don’t mean to promote any other forum but here is the thread I wrote over there: https://www.jeepforum.com/forum/f12/definitive-info-passport-rodeo-dana-44-a-3006465/?amp=1 The first post was edited to reflect all the current info. I had a D44 from a JK, 95 rodeo/passport, 97 rodeo/ passport and 2000 rodeo/passport. Also had 4 exploder 8.8’s when going through the comparisons. I was building and selling most of these axles and had the option to keep any of them. The rodeo d44 is what I chose after working on them all. Lighter center section with much better clearance, thicker and stronger axle tubes, set 10 bearings upgradeable to set 20, 12.3” brake rotors, larger and stronger ring and pinion. Oh, and about 1/3 the price of the 8.8 at our local yards back stateside. The only down side you have to sort out is the wheel pattern. Link to comment Share on other sites More sharing options...
Pete M Posted May 23, 2020 Share Posted May 23, 2020 2 hours ago, ghetdjc320 said: Don’t mean to promote any other forum but here is the thread I wrote over there: https://www.jeepforum.com/forum/f12/definitive-info-passport-rodeo-dana-44-a-3006465/?amp=1 can you copy/paste thread about it for here? I'd love to get that into the DIY list. Another great option is the Liberty 8.25. it's the right wheel bolt pattern, 03-07 comewith disks, and is uber-plentiful in the junkyards right now. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted May 23, 2020 Share Posted May 23, 2020 7 hours ago, Pete M said: can you copy/paste thread about it for here? I'd love to get that into the DIY list. Sure thing! And if anyone needs more info, just let me know Link to comment Share on other sites More sharing options...
ghetdjc320 Posted May 24, 2020 Share Posted May 24, 2020 9 hours ago, ghetdjc320 said: Sure thing! And if anyone needs more info, just let me know done Link to comment Share on other sites More sharing options...
BeatCJ Posted May 25, 2020 Share Posted May 25, 2020 On 5/23/2020 at 6:34 AM, Pete M said: Another great option is the Liberty 8.25. it's the right wheel bolt pattern, 03-07 comewith disks, and is uber-plentiful in the junkyards right now. I immediately went to Google after reading that,every single one I found was a 3.7 V-6. And the 4 cylinder has 4.10s. Link to comment Share on other sites More sharing options...
Dzimm Posted May 25, 2020 Share Posted May 25, 2020 On 5/23/2020 at 8:34 AM, Pete M said: Another great option is the Liberty 8.25. it's the right wheel bolt pattern, 03-07 comewith disks, and is uber-plentiful in the junkyards right now. This^^^^ I did the XJ 8.25 on my blue truck and just recently did the Liberty 8.25 on my red truck. Definitely the way to go, as Pete said, they are plentiful right now, it comes with disks and only about an inch or so wider than the XJ/MJ axle. Grab a prop valve from a Grand Cherokee with rear disks and you are set. Link to comment Share on other sites More sharing options...
Pete M Posted May 25, 2020 Share Posted May 25, 2020 11 hours ago, BeatCJ said: I immediately went to Google after reading that,every single one I found was a 3.7 V-6. And the 4 cylinder has 4.10s. took me a couple years to find a 4.10 pair near me and for a reasonable amount of money (I needed the front diff too since they are going into my Liberty). If you think the rear axle is hard to find, just try the 4.10 KJ front. not a lot of people rejected the v6 but still wanted 4wd. Link to comment Share on other sites More sharing options...
BeatCJ Posted May 25, 2020 Share Posted May 25, 2020 I just picked up an XJ Front with 4.10s today. It needs bearings, but the gears are good. I have the matching 8.25 rear end, but it's earmarked to fix the son's Cherokee. Be nice to get it out of my driveway. Probably should stop the threadjacking... Link to comment Share on other sites More sharing options...
ComancheMadness Posted May 25, 2020 Author Share Posted May 25, 2020 @beatcj whats your info, ill like to get it off your hands ! Link to comment Share on other sites More sharing options...
BeatCJ Posted May 25, 2020 Share Posted May 25, 2020 Sorry, get it fixed and back on the road/trails. Get it out of my driveway and into his. Link to comment Share on other sites More sharing options...
