MontanaManche Posted May 21, 2020 Share Posted May 21, 2020 So a little while ago my fuel pump decided to go out on me, not really a huge issue but i filled up my tank all the way probably 20 miles before hand. Anyone know the best way to drain the gas tank safely? I tried siphoning it but i think there is some sort of anti siphon valve. Can i drain from the line with the fuel filter? Link to comment Share on other sites More sharing options...
70barracuda Posted May 21, 2020 Share Posted May 21, 2020 I used a small 5/16 plastic hose. Was the only one I had that fit. Took a bit of wiggling but I got it and it drained the tank almost till empty. Took a while though. Link to comment Share on other sites More sharing options...
Jaime Posted May 21, 2020 Share Posted May 21, 2020 I did this once in a similar situation. Buy the cheapest in-line fuel pump you can get and hook it up before the fuel filter. Then hook up power to it and let it go. On a sidenote can you check to see if there’s anything in the filler tube that might make the fuel spill over when the tank is getting filled. Link to comment Share on other sites More sharing options...
Dzimm Posted May 22, 2020 Share Posted May 22, 2020 You just need a section of small hose long enough to reach the bottom of the tank and into a gas can. Then place a larger section of hose into the fuel filler area, doesn't have to go into the actual nozzle hole, just where the cap covers up. Then use a rag to tightly plug any extra airgap around the filler next and take a deep breath and blow real hard for a couple seconds into the larger hose, may take a couple times but your siphon will start. Compressed air works even better, just need enough pressure to get the fuel moving. Or get a cheap hand operated siphon pump from Walmart or the auto parts store. To stop the siphon, pull the hose up out of the gas in the tank. With a full tank you will need to fill a gas can a couple times, put the extra gas into another vehicle, I'm sure you could find a friend who would be willing to help you dispose of the gas. Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 22, 2020 Share Posted May 22, 2020 2 hours ago, Jaime said: filler tube that might make the fuel spill over when the tank is getting filled. You too huh? I went through every piece attached and replaced some pieces to the tank and came up empty handed. Mostly what I came up with is watch the pump and know the volume that goes in your tank and listen for the nozzle to start sounding like it is filling up a cup or bottle to the top. Link to comment Share on other sites More sharing options...
Dzimm Posted May 22, 2020 Share Posted May 22, 2020 2 minutes ago, eaglescout526 said: You too huh? I went through every piece attached and replaced some pieces to the tank and came up empty handed. Mostly what I came up with is watch the pump and know the volume that goes in your tank and listen for the nozzle to start sounding like it is filling up a cup or bottle to the top. I have found that not inserting the nozzle fully seems to help with this problem, put it about 3/4 of the way in and I rarely have the issue anymore. I did it the way you describe for quite a long time, kind of annoying. Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 22, 2020 Share Posted May 22, 2020 1 minute ago, Dzimm said: put it about 3/4 of the way in and I rarely have the issue anymore Ive done that too with some success. I still have to catch it at the right moment though. I have another theory but I don't think it will solve the problem. Anyways I do have this topic posted somewhere if we do want to continue this without hijacking this thread. Link to comment Share on other sites More sharing options...
Dzimm Posted May 22, 2020 Share Posted May 22, 2020 3 minutes ago, eaglescout526 said: Ive done that too with some success. I still have to catch it at the right moment though. I have another theory but I don't think it will solve the problem. Anyways I do have this topic posted somewhere if we do want to continue this without hijacking this thread. Good call Link to comment Share on other sites More sharing options...
Jaime Posted May 22, 2020 Share Posted May 22, 2020 Cool I’ll look for it. Link to comment Share on other sites More sharing options...
Pete M Posted May 22, 2020 Share Posted May 22, 2020 did you check power and ground first? the pump grounds to the ground behind the drivers taillight. Link to comment Share on other sites More sharing options...
