I have two MJ's. Both Renix 4.0 engines. Both appear to be fully stock. The 88 4WD is rough body and some floor rust, but has good engine, trans, transfer, and axles. The 87 2WD has great body with no rust and only minor body damage and sold interior, not sure about engine at the moment.
My plan, move all the 4WD components from 88 4WD to 87 2WD.
My main question, why do i have to change out transmission? What is the main difference between the two trans?
Also, since this will be my first swap, what are major pitfalls to look out for while doing this?
I found some old discussions on this topic, from years ago, wanted to see if there was any new tips or tricks?
Thank you for any help offered.
The 2wd transmission will not accept the transfer case. So you have to swap the 4wd transmission also.
Are both trucks same bed length?  If so, drive shaft from the 4wd should swap over (unless one auto and the other is manual).  Also what axle in the rear do you have  - D35 or D44?  That may affect the drive shaft, also.
The front axle and drive shaft should swap over without any issues.
The difference is that the 4WD transmission has the output end set up to have a transfer case attached to it. The 2WD transmission has a long tailshaft with a splined end that accepts the front yoke of the driveshaft directly. It's easier to swap the transmissions than it would be to try to take the 2WD transmission apart in the vehicle and reassemble it as a 4WD tranny.
Hello. Here are answers to the questions. Thanks for the help.
The 4WD has the following
Rear is Dana 35 (42968) dated 02/24/87
Front Dana 30 (40869) dated 07/24/85
The 2WD has the following
Dana 35 (42106) Dated 11/15/85
Both beds are the same, 6 ft short bed.
Both are manual 5 speed trans
Overall seems to be the parts are interchangeable? Any thoughts or concerns?
You should be good to swap everything. You will have to use the 4wd transmission. You will have to check the rear gear ratio in the 2wd and see if it matches the front. If it's doesn't you'll have to swap the rear also.
both should be 3.07 but is better to check, just in case some PO had messed with it
Looks like both rear ends are identical. I attached a picture of both rear end tags. Both are Dana 35C with 3.08 gear ratio as both have 4.0 IL6 with 5 speed manual gear boxes.  And I know over time someone could have messed with the gears, but overall everything looks very stock on both vehicles.
Based on the rear tags, any concerns or items to look out for as I make the swap?
Thank you for the feedback.
1 hour ago, omega_rugal said:
yes, 3.08... i wonder why Jeep even bothered putting such ratios on 4WD models, the 3.55 would be the bare minimum for off-roading
It was the '80s.  Every (cheap) effort to increase MPG was implemented.  (See front axle CAD.)  Also, the 3.07 was offered only in the 5 spd Jeeps.  Autos and 4 cyl/4 spd. came with 3.55 and higher ratios.
To meet Fed CAFE standards, off-roading wasn't a thought.
you can do a quick and easy check of the ratio by spinning one tire around exactly twice while counting the number of times that the driveshaft rotates.  just past 3 rotations is 3.08. :L:
At least it's not the 2.73 gears that were original in my '81 CJ-5 4 Speed. On most trails, finesse was out of the question. Swapping to 3.55 axles was huge!
