j_gevans Posted April 4, 2020 Share Posted April 4, 2020 My '88 MJ's speedometer will fluctuate up to +/- 5 MPH at lower speeds (usually below 25) but doesn't at higher speeds. I was wondering if anyone else has seen this before and might have any idea what could be causing it to do so or what could fix it. Thanks for any help. Currently working on restoring my first MJ and am sure this will be the first of many questions to come. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted April 4, 2020 Share Posted April 4, 2020 The cable is probably sticking a bit, probably need to lube the cable or replace it Link to comment Share on other sites More sharing options...
Comanchejess Posted April 6, 2020 Share Posted April 6, 2020 On 4/4/2020 at 9:46 AM, j_gevans said: My '88 MJ's speedometer will fluctuate up to +/- 5 MPH at lower speeds (usually below 25) but doesn't at higher speeds. I was wondering if anyone else has seen this before and might have any idea what could be causing it to do so or what could fix it. Thanks for any help. Currently working on restoring my first MJ and am sure this will be the first of many questions to come. My 87 does this since ive had it for almost 3 years Link to comment Share on other sites More sharing options...
watchamakalit Posted April 6, 2020 Share Posted April 6, 2020 On 4/4/2020 at 10:48 AM, Strokermjcomanche said: The cable is probably sticking a bit, probably need to lube the cable or replace it I would have to agree. I had the same issue before I replaced my cable. Now smooth as a babys bottom. Link to comment Share on other sites More sharing options...
j_gevans Posted April 11, 2020 Author Share Posted April 11, 2020 On 4/6/2020 at 3:57 AM, watchamakalit said: I would have to agree. I had the same issue before I replaced my cable. Now smooth as a babys bottom. Ok thanks! I'll check it out once I finish a few other projects! Link to comment Share on other sites More sharing options...
JMO413 Posted April 11, 2020 Share Posted April 11, 2020 I would also add to double check the routing. Make sure there's no sharp bends and that it is secure. Link to comment Share on other sites More sharing options...
j_gevans Posted April 11, 2020 Author Share Posted April 11, 2020 1 minute ago, JMO413 said: I would also add to double check the routing. Make sure there's no sharp bends and that it is secure. Ok. Thanks! Link to comment Share on other sites More sharing options...
Drahcir495 Posted April 11, 2020 Share Posted April 11, 2020 I have a similar but stranger issue and here is what kinda worked for my 1990. I lube the cable and did not help. Checked the Speedo cable routing and that was fine. I backed off the connection to the transfercase and that definitely helped. Still only accurate up to 35 mpg with a little fluctuations until 40. Ask all the questions you want here. We have all have needed answers at one point or another Link to comment Share on other sites More sharing options...
boxyjeep Posted April 11, 2020 Share Posted April 11, 2020 New cable is $20. Just get it and replace it. Be prepared--it's a b*@ch to swap it out. Link to comment Share on other sites More sharing options...
