1JTHL6310HT182860
edub369
1987 Jeep Comanche Base4x4
2.5L which I stroked to 3.0L, Clay Smith performance cam, lifters, valves and springs (through Hesco), 3” lift and a set of Wrangler rims - everything else is stock.
Build date: June 87
Status: On the road, but still a “project car” until I get it as good as my limited skills will allow.
Notes: This was a one owner car until I registered it in 2019. It came with the original dealer, pear shaped 80’s style key chain and original dealer title envelope, which were nice touches. It’s navy blue, tan interior with a bench seat and factory roll bar. 3 of the 4 pillars rusted out, so it needs repair before I put it back on.
Edited by edub369
adding info
2.5L which I stroked to 3.0L - everything else is stock.
Build date: June 87
need a VIN :D  and then go start a build thread so we can see more pics! :drool:
  • 6 months later...
On 3/29/2020 at 12:57 PM, eaglescout526 said:
I can get you a build sheet as long as I get two things. One; A 3.0L? Please tell us. Two; I need a VIN please.
VIN posted! The stroker is an ATP stroker kit- no change in bore. According to ATP I should have roughly a 30hp/ 48lbs of torque increase.
Link to kit: https://www.ebay.com/itm/153935400418
Neat!! I’ll get you a build sheet this afternoon. Computers here at work blocked me from getting on CC. Lunch is now boring.
Body jl61
Build 6/15/87
X1  DESCRIPTION NOT AVAILABLE
-YY  DESCRIPTION NOT AVAILABLE
ADL  Skid Plate Group
APA  Monotone Paint
BCQ  750 Amp Maintenance Free Battery  CBA  Straight Back Bench Seat
CGX  RR Head Restraints Outboard Seating  DDQ  5-Speed Manual Transmission
EPD  DESCRIPTION NOT AVAILABLE
GAC  Tinted Glass Windows
GFD  Rear Sliding Window
GPB   Mrrs
HAA  Air Conditioning
HCC  Do Not Use - See HCA
JAY  DO NOT USE - See JP, KA classes JGB  Digital Clock
JHA  Var Intermittent Windshield Wipers  JJA  Cigar Lighter
KD8  STRIPE/BADGE/MOLDING/DELETE  LAP  Shift Indicator Warning Lamp
LMA  Halogen Headlamps
MBJ  Black Bumper
MDA  Front License Plate Bracket
MWB Sport Bar
NAA  Federal Emissions
NMB  Standard Duty Engine Cooling
PXF  paint code
QXF  paint code
SBA  Power Steering
SUA  Tilt Steering Column
TBG  Compact Spare Tire
WJD  15X7.0 Styled Steel Wheels
3LQ  DESCRIPTION NOT AVAILABLE
  • Pete M changed the title to 1JTHL6310HT182860
7 hours ago, eaglescout526 said:
Yeah it upsets me. Not like CC is infringing upon my work but all I get is can not connect to CC. Doesn’t even say it’s blocked. But thanks for getting him the build sheet.
which browser are you using?
  • 1 month later...
