Transmission and Tranfer-Case ?
you'll fill it through the fill hole until it won't take any more. :L:  it's situated at that exact spot for that reason.  obviously this will need to wait until you've installed it back into the truck.  :D
it says in the book my friend has 2.1 liters
i guess i will start there and see how it looks
i also accidentally broke my Vacuum Switch on the T-Case
my question is if i install a Posi-Lock on the front axle
will that then solve my problem and bypass this switch ?
16 hours ago, AMC86Kid said:
Thanks guys will do
also is there a specific amount of fluid to put in or do you just fill it up to about half way ?
Fill it with ATF until it starts coming out of the fill hole.
:laugh: The first read-through of your comment "
31 minutes ago, Pete M said:
tell you to stop spreading your ideas on using 2-low.
" I read it as "tell you to stop spreading your lies"! Took me aback for a moment until I slowed down and read ALL the letters in ALL the words. :))
Anyways: Team 2wd Low FTW! Anyone interested should look into a posi-lock system. Combine that with a boostwerks shift linkage for the 231. Everything is awesome!
It is important to read alllllll the words. :D
22 hours ago, AMC86Kid said:
Sounds like a plan I will order a a Posi-Lock so I can ditch the vacuum sensor switch
Why?
Do you do any type of off-road driving where you would need to use 2-wheel drive in low range? If not, save your money and just lock the front axle in the engaged position permanently. Jeeps with the Selec-Trak transfer case don't have the front axle disconnect, and the factory stopped using it with the Command-Trak transfer case around 1991. It will not hurt anything to drive in 2WD with the front axle engaged.
Thanks for your advice eagle
but I do want to able to have 2wd low
I'm sure it helps a lot driving down hill
and jdog
i haven’t bought the kit yet because
you can order ones with or without
the band so I wanted to see what I needed
first then order it
3 hours ago, AMC86Kid said:
since they don’t sell new ones
That band appears burnt, should look like the one in previous pic. which looks good to me. these  parts should be available if you can't find one new visit local mom and pop trans shops, most of these guys are hoarders and may have one for cheap
Now for hopefully my last problem
how do you guys recommend I remove this broken brass fitting
I got a new one the fits the same thread size and there’s no access to it inside the tranny just outside like how it looks in the pic,  any advice ?
