89 MJ 4.0L renix. Not the original motor, has an HO block but everything else is renix era (I think).
MJ was starting and running fine. It would sometimes buck a bit when starting and I noticed the distributor was clocked quite a bit off from other 4.0s I've seen, so I decided to do cruisers #12 and #13 tips on TDC and distributor indexing.
(Old photo, notice distributor clocking. #1 terminal where #4 terminal "should" be)
While I had the distributor out I noticed someone had already cut the mounting tab off. The pulse ring was super rusty so I took it off and cleaned with it a wire wheel. There was also a bit of oil and mud inside the distributor so I cleaned that up best I could.
Set #1 cylinder to TDC, did the finger pressure test, checked piston location and lined up the harmonic balancer mark to the 0 timing mark. Reinstalled distributor and wires, starter works but it won't turn over. There is spark at the plugs and fuel pressure at the pump. I've redone the process half a dozen times to no avail. I even just started clocking the distributor in various places to see if I could get any attempt to turn over and still nothing. Its driving me crazy, I hope I can get some answers. Thanks.
(Last non working setup: #1 set to TDC, rotor at 5 o'clock, trailing end of rotor at #1 terminal per inspection window in cap)
1 hour ago, cruiser54 said:
I wonder if your harmonic balancer outer ring has slipped and it's not showing true TDC.
I was wondering that too, but I made sure #1 cylinder was at TDC and it lined up with the 0 mark on the timing like it was supposed to. The balancer def does not look like that.
Your photo of the distributor rotor shows the centering contact is bent down with signs of arching. Might just be the photo though.
Yes it was, I did fix that. I should note all these parts were in good working order when I parked it. They have less than 20 miles on them, as my MJ has been sitting for awhile.
I got it running! Theres out I wasnt lined up with the correct cam tooth, just had to advance the oil pump driveshaft clockwise a tiny bit. I also found this picture which helped give me a better visual of rotor/dist placement at TDC. After doing the process so many times I guess I'm an expert in Renix dist replacement now. 😀😥☹🤷‍♂️ Now to replace my 98 XJ distributor....
indexing only has to do with inyector timing, if the ECU can not sync after a few tries it switches to batch injection, it could be a bad rotor or you didnt install the dizzy at TDC
oh never mind you got it working
2 hours ago, Airborne Janitor said:
XJ distributor....
Distributor-Index.png.885afc5b7274b39e4625f6a79cfe06c0.pngbeen looking for this
