Sullie2399 Posted February 13, 2020 Share Posted February 13, 2020 I have a no start issue have change everything in the Ignition system still no spark found bad ecu replace with new one no fuel pressure fixed that problem the back to no spark killed ecu wait on new one have tones of Questions about my mj oil light stay on with key off unplug the red coil wire it goes off need help Link to comment Share on other sites More sharing options...
jdog Posted February 13, 2020 Share Posted February 13, 2020 Picture of said red wire? Stock 1988 swb 4.0 ax15 np 231. Link to comment Share on other sites More sharing options...
Sullie2399 Posted February 13, 2020 Author Share Posted February 13, 2020 Red that plug in the coil can get pic later if need be there are two plus in the ignition module and one red wir to the coil the guy I got it from change all this stuff don’t know what really goes where first Renix Link to comment Share on other sites More sharing options...
JMO413 Posted February 13, 2020 Share Posted February 13, 2020 The red wire doesn't go to the coil only the two plugs. This had been a problem for a few people on here. The red wire would be for the under hood light if it had one. Link to comment Share on other sites More sharing options...
Sullie2399 Posted February 13, 2020 Author Share Posted February 13, 2020 Thanks for the info wish I could get it to run Link to comment Share on other sites More sharing options...
JMO413 Posted February 14, 2020 Share Posted February 14, 2020 http://cruiser54.com Go here and do 1-5 it is a must for a Renix. I would test the CPS. That test is also on the website above. Link to comment Share on other sites More sharing options...
JMO413 Posted February 14, 2020 Share Posted February 14, 2020 Truck info is a big help with questions like this you can add them to your signature. You go to account, Then account settings, then settings area to add them. Link to comment Share on other sites More sharing options...
Sullie2399 Posted February 14, 2020 Author Share Posted February 14, 2020 Have done 1 thru 5 lol it won’t to start but it just won’t take off has been setting a long time replaced injectors got fuel got spark just can’t get to start running out of hair to pull Link to comment Share on other sites More sharing options...
Pete M Posted February 14, 2020 Share Posted February 14, 2020 how long has it been sitting? Link to comment Share on other sites More sharing options...
Sullie2399 Posted February 14, 2020 Author Share Posted February 14, 2020 10yrs or so Link to comment Share on other sites More sharing options...
jdog Posted February 14, 2020 Share Posted February 14, 2020 What's the compression numbers, with it sitting this long what steps were taken before you attempted to start it? Stock 1988 swb 4.0 ax15 np 231. Link to comment Share on other sites More sharing options...
Pete M Posted February 14, 2020 Share Posted February 14, 2020 16 minutes ago, Sullie2399 said: 10yrs or so 10 year old gas is not going to fire up. Link to comment Share on other sites More sharing options...
Sullie2399 Posted February 14, 2020 Author Share Posted February 14, 2020 17 minutes ago, jdog said: What's the compression numbers, with it sitting this long what steps were taken before you attempted to start it? Stock 1988 swb 4.0 ax15 np 231. New tank new pump all Ignition parts lubed the cylinders downIgnition parts lubed the cylinders down Link to comment Share on other sites More sharing options...
Pete M Posted February 14, 2020 Share Posted February 14, 2020 I once had some corrosion on the power wire to the coil cause a weak spark that just couldn't fire the gas. the spark was there, but very weak. Link to comment Share on other sites More sharing options...
Pete M Posted February 14, 2020 Share Posted February 14, 2020 triple checked the plug wire order? was the distributor removed at any point? Link to comment Share on other sites More sharing options...
Sullie2399 Posted February 14, 2020 Author Share Posted February 14, 2020 Yep it is new have Check it per instructions from the cruiser54 steps Link to comment Share on other sites More sharing options...
jdog Posted February 14, 2020 Share Posted February 14, 2020 Where are you checking spark? What does the spark look like, what's the compression numbers, just caused you lubed the cylinders still doesn't tell me the numbersStock 1988 swb 4.0 ax15 np 231. Link to comment Share on other sites More sharing options...
Pete M Posted February 14, 2020 Share Posted February 14, 2020 46 minutes ago, Sullie2399 said: Yep it is new have Check it per instructions from the cruiser54 steps that's alwasy a red flag for me. I can't tell you how many times I've read that someone has put those in 1 tooth off or 180* off. Link to comment Share on other sites More sharing options...
Sullie2399 Posted February 14, 2020 Author Share Posted February 14, 2020 Goin to do some more checking tomorrow it had a new dist in when I got it so many part have been changed I’m having to back track the Previous owner that couldn’t get it to run I’m get a lot of good info on here I have no experience with Renix system and will check comp in the morning Link to comment Share on other sites More sharing options...
cruiser54 Posted February 14, 2020 Share Posted February 14, 2020 Sorry, but I don't respond to posts/threads with no punctuation. Link to comment Share on other sites More sharing options...
Sullie2399 Posted February 14, 2020 Author Share Posted February 14, 2020 Sorry Just trying to some info Didn’t think grammar was so important if someone wouldn’t give you information thanks for the tips that you have posted jerk Link to comment Share on other sites More sharing options...
Pete M Posted February 14, 2020 Share Posted February 14, 2020 some of your posts have been difficult to read. Link to comment Share on other sites More sharing options...
JustEmptyEveryPocket Posted February 15, 2020 Share Posted February 15, 2020 11 hours ago, Sullie2399 said: Sorry Just trying to some info Didn’t think grammar was so important if someone wouldn’t give you information thanks for the tips that you have posted jerk Not piling on here, but I don't understand this statement at all. What are you trying to ask here? Link to comment Share on other sites More sharing options...
cruiser54 Posted February 15, 2020 Share Posted February 15, 2020 Link to comment Share on other sites More sharing options...
klaichkr Posted February 15, 2020 Share Posted February 15, 2020 I'm confused, people that come to this site for help must comply to all grammatical rules? Was there an education requisite on the rules page or can people just try to work with people when they are having problems with their vehicles. I understand it's not as easy to diagnose a problem when it's hard to understand what's going on, but people are coming here for help with problems. Not so the people on here can give them sh*t for their grammar. Link to comment Share on other sites More sharing options...
