Has anyone put a turbo on the i4
12 hours ago, NwiComanche said:
So I recently purchased a 1989 inline 4
when you get a chance, you should put your truck's specs in your signature. :L:
what size tires are what gearing are you at now?
You need the engine and dash harnesses from an MPFI MJ/XJ, the ECM, gauge cluster, fuel pump/sending unit, fuel lines,flywheel, a complete MPFI engine and pretty much everything that plugs into it, and a few other things.
It's much easier to put in a complete MPFI 2.5l, but you could strip your TBI 2.5l down and redress it as an MPFI.
It's a pretty big project and rarely done, which is why you don't see much information on the swap.
