MJ not running properly in first and second.
My 1990 Comanche with the in-line 6 and manual tranny is not driving right, when I put it in first and second and let out the clutch it barely will stay running, I have to feather the clutch to keep it going, as soon as I get to 3000 rpm it runs fine in both gears, and it runs fine in 3+. I can rev it with the clutch in no problem. Any ideas?
(is this the right place to post about things like this?)
you mean it runs but lacks power?
there´s a vacuum leak in MAP or bad Throttle position sensor but since it can rev up to 3000 rpm fine, my vote goes for the MAP sensor vacuum leak, without it the ECU can not guess how much load is on the engine...
