2 Wheel Drive Transmission
7 minutes ago, Phillip Gwin said:
I added information on my profile, I don't see where I put it that it shows up when I post.
Click on your username (upper right hand corner) and go to Account Setting, then go to Signature. Put your vehicle(s) Year, Engine and Transmission information there.
Well...I have never done a trans on a 1998 MJ......but my best guess is no
....answer your own questions... Does the trans you are asking about have a visible removable tail shaft...the gm trans you reference have 4 bolts that you take off to drop the tail shaft.... Do you see that on the trans you want to convert?
