Wiper issues
Since I purchase my mj I’ve had a very slow wiper speed. Didn’t matter what speed I turned it to. It was always on the same speed, slow!
Recently it just stopped working. I’ve had several CJs/YJs and would replace the motor, always fixed issue.  It’s past the date of inspection, wipers and horn are the only issue but I’m getting horn sorted. Should I replace the motor then go the the next item if that doesn’t fix or ????
Cruisers tips is a good place to start. An additional ground and a good refresh of the existing grounds can work miracles.
http://cruiser54.com/
My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
Edit: dang I was to slow. Lol
6 hours ago, coolwind57 said:
If you get a chance, go check out my write-up on wipers.  There's some good stuff in there from my experience in this area and lots of pictures.
Nice read! I’ve ran through it and will check several items tonight.
