rocklaser Posted July 10, 2019 Share Posted July 10, 2019 anybody recommend a good way to bypass one of the fuses in my fuse block. The fuse controls the parking lights, dash and license lights. I cannot break loose the screws on the block to pull out the block. every time I pull out the light switch it blows the fuse. any help greatly appreciated. Link to comment Share on other sites More sharing options...
Minuit Posted July 10, 2019 Share Posted July 10, 2019 That circuit is drawing excessive current (most likely due to a short to ground in the wiring). Do not bypass the fuse. It is there for your safety and the safety of the truck. You need to fix the problem. For that, you'll need an accurate wiring diagram, a multimeter, and the time to trace through the headlight/parking light circuit. If you don't feel confident doing it yourself, get someone who knows auto electrical to help you. An easy place to start would be at the headlight switch connector. You'll be checking for short circuits to ground on all of the circuits that are protected by the fuse that keeps blowing. I don't have access to wiring diagrams for '87, but there should be someone who can help you with that on here. Link to comment Share on other sites More sharing options...
Pete M Posted July 10, 2019 Share Posted July 10, 2019 what do you mean by " cannot break loose the screws on the block"? Link to comment Share on other sites More sharing options...
cruiser54 Posted July 11, 2019 Share Posted July 11, 2019 Don't bypass it. Listen to these ^^ guys. Link to comment Share on other sites More sharing options...
gogmorgo Posted July 11, 2019 Share Posted July 11, 2019 X2 on the headlight switch connector being the first place to check. Once you've got that sorted, you'll want to look into this to prevent cruiser's photo from happening to you: As the switch ages, the contacts get weak, and bad contacts mean heat, and the heat melts the connector and burns off the insulation on the wires. After mine caught fire, I tried to find a connector in junkyards, and every one of a dozen or so I checked was already melted. Link to comment Share on other sites More sharing options...
JMO413 Posted July 12, 2019 Share Posted July 12, 2019 Third vote for headlight switch and connector. Followed by a harness upgrade. Link to comment Share on other sites More sharing options...
