No Start 4.0
Well got everything up-to-date and the truck is - Ready-to-Start.
___________________________________________________________________________________________________________
Check out my Build :
______________________________________________________________________________________________________________
Now :
All Maintenance and Friction Items have been :
Inspected
Refurbished
Repaired
Replaced.
This 1991 - 4.0 - has not been started since, (per Inspection Sticker) - 2011.
I replaced the ICU with a refurbished from Houston.
(The original appeared to be in bad shape with the mounting stud broken-off…)
Had replaced the CPS with Rock Auto - ‘Standard’ brand.
Complete Fuel System(fuel tank to injectors), has been gone-through.
New Fuel Tank
New Bosch Fuel Pump
Rebuilt In-Tank Sending Unit
New Fuel Filter
Fuel Injectors Pro Cleaned
Cleaned Fuel Rail
New Pressure Regulator
Fuel Pressure Gauge/Fuel Rail
Crank-
-No-Start.
-NO Fuel Pressure - on fuel rail gauge
KeyON-
Remove Fuel Pump Relay-
Jumper Pump-
Hear Pump-
Fuel-Rail Gauge shows building-pressure-
-Fuel Pump is Working
Remove New CPS-
Install the Old-Original One-
Crank-
-No Start
Next
I am going to pull a spark plug
And crank to see I I am getting - fire.
This is as far as I have gotten.
Without wasting time, what
would be the next way to go.
Any help would be appreciated.
youngfred
11 minutes ago, Dzimm said:
Clean up the ground behind the drivers taillight.
You've already narrowed it down to fuel and from the sounds of it, you aren't getting power to your pump.
Thanks,
I will check that.
I forgot to mention that the Dash Fuel Gauge does not move, with Key-ON.
I will clean the Ground Point behind the taillight.
youngfred
10 hours ago, youngfred said:
KeyON-
Jumper Pump-
Hear Pump-
Did you jumper the fuel pump at the fuel pump relay block? Pin C216_1(30) to C216_4(87). Use a fused jumper.
1 hour ago, Ωhm said:
So when you jumped the fuel pump at the fuel pump relay block you got fuel pressure, but still had a NO START condition?
Ahhh...(said the blind-man) I see, I see.
I jumped the fuel pump, at the relay - only, to test the pump.
So, should I fuse-jumper the pump that way and try to start?
I wil try that after I check  -  Ground.
youngfred
1 hour ago, Jeep Driver said:
I'd suggest reinstalling the original ECU.
And test your fusible links, all seven of those...........they belong in the trash but that's another matter.
Original ECU - GONE - Core Exchange.
youngfred
Two things:
1) 50psi seems high for fuel rail pressure, could be the gauge used. Pull and check plugs for wet fouling.
2) Since you don't get fuel rail pressure when the fuel pump relay is installed. Disconnect and check for voltage at the Ignition Control module (ICM) connector C213_A with the KEY ON and during CRANK.
1 hour ago, youngfred said:
No, I have not.
I will do that, next.
Thanks,
youngfred
Static tested - Unplugged the CPS - Ohmmeter shows OPEN -between B and C.
Plugged in the CPS and checked for Voltage at the three Pins
With Key-ON and with Key-START.
No Voltage readings.
youngfred
18 minutes ago, Ωhm said:
Two things:
Went back and retested with:
KeyON-START-
Fused Jumper at Relay-
JEGS- 0-60 psi fuel pressure gauge -
This time, up to 55psi -
Can smell fuel at fuel rail area - no leaks, though.
No Fuel Fouling - on Plugs
youngfred
Disconnected the Neg Batt cable-
Unscrewed the ECM Connector-
Sprayed Contact Cleaner-
Sat for about 30 minutes-
Plugged both, back in-
KeyON-START-
-Started-right-up, like it had been running all along.
Yea.
Thanks to all of you that contributed to finally getting
this Big-City, Country Boy, running and on-the-road, again.
Thanks, again - very good-place;  here.
youngfred
11 hours ago, bbdude said:
Hi   nice rig!  ))     I have the 88 Comanche 4 lit short bed.   Mine was in storage for 7 years as well.  We by-passed relay on upper left side under hood to check the fuel pump if was working adequately and it turned out while it was pumping, it wasnt pumping enough, which explained the start temp but no idle for my situation;  if that helps.   ))
 One question if you good folks would be so kind,  where on earth do you get the sending unit for this model?   Does anybody have a suggestion?   Mopar -no  Dealer-no  JCWhitney+Ebay+Amazon just generic-won't fit.   Has anybody had any luck finding where one can get the fuel sending unit for 88 Comanche 4 liter?
Thanks so much for your comment help in advance.  ))
This thread is about a no-start condition, and it has been resolved. You'll get more/better answers to your question about a fuel level sender if you start your own thread. I'm closing this one.
  • Eagle locked this topic
I split off his post into it's own thread and unlocked this one just in case something pops up. :L:
  • Pete M unlocked this topic
