Vineyard86manch Posted April 16, 2019 Share Posted April 16, 2019 So when I bought my ‘86 a year ago I took the advice of the fine folks here at CC and pulled the carpet out to see what the floors looked like. The drivers side was not great but nothing a grind and some Por-15 couldn’t fix. The passenger side had very little rust. I then took ATV sealant to the plasti-chrome windshield trim and around the base of the antenna. Recently I started noticing water puddling on the passenger side floor, and none on the drivers side. So I pulled the carpet again and did the baby powder test to see where the water might be coming from. This morning we had an hour of thunderstorms and then I went out and checked the floor and here’s what I noticed. Judging from the areas pointed at by the arrows, any idea where the water is coming in from? Link to comment Share on other sites More sharing options...
Pete M Posted April 16, 2019 Share Posted April 16, 2019 the drivers side of my 86's windshield was leaking up at the roof and the water was traveling down inside the A-pillar and dumping out similar to what you see there. Link to comment Share on other sites More sharing options...
rylee144 Posted April 16, 2019 Share Posted April 16, 2019 Mine was the windshield too. Just got a new one with the rubber gasket, problem seems to be solved. Mine also puddled on both sides. Link to comment Share on other sites More sharing options...
Minuit Posted April 16, 2019 Share Posted April 16, 2019 That's a pretty characteristic spot for either a windshield or antenna grommet leak. The antenna grommet will be easy to see by removing the kick panel trim. Link to comment Share on other sites More sharing options...
Vineyard86manch Posted April 16, 2019 Author Share Posted April 16, 2019 Thank you guys for the advice! I thought I had patched everything up tight but I guess not:// Link to comment Share on other sites More sharing options...
Pete M Posted April 16, 2019 Share Posted April 16, 2019 there is no end to the battle. every single thing that could possibly leak has leaked for someone at some time. firewall grommets, crumbling HVAC foam seals, cowl drains, door seals, rear window, missing plugs in the floor, etc. It's something we all have to stay on top of. Link to comment Share on other sites More sharing options...
Minuit Posted April 16, 2019 Share Posted April 16, 2019 At this point, I have to assume that the MJ was designed to leak water, and that all of our trucks are actually working as intended. I mean, think about it. Why else would you use an unsealed connector at the wiring harness bulkhead? Why else would you use crumbly foam gaskets for all of the massive holes in the firewall for the HVAC? Why would you use a crappy, thin grommet for the antenna that wallows out and lets water run right down the antenna cable into the cab? Why would you design the firewall in a way that seemingly directs water towards possible leak points? I've never heard of a vehicle that has as many problems with water leaks into the interior, and in as many different places, as the early XJ and MJ. Link to comment Share on other sites More sharing options...
JMO413 Posted April 16, 2019 Share Posted April 16, 2019 My leak was there windshield. From what I could tell it was factory and they weren't too worried about installation. Mine had two doors the urethane was almost not there and spots that were extremely think and wide. One spot was not attached at all one the drivers side. Link to comment Share on other sites More sharing options...
zomeizter Posted April 19, 2019 Share Posted April 19, 2019 On 4/16/2019 at 9:45 AM, Pete M said: there is no end to the battle. every single thing that could possibly leak has leaked for someone at some time. firewall grommets, crumbling HVAC foam seals, cowl drains, door seals, rear window, missing plugs in the floor, etc. It's something we all have to stay on top of. I fought all mentioned leak sources here and eventually gave up and "engineered" some drain holes on the floor pan...water leaks in, then it immediately drains out, no carpet installed... Link to comment Share on other sites More sharing options...
gogmorgo Posted April 19, 2019 Share Posted April 19, 2019 There are drain plugs in the floor pans already. Link to comment Share on other sites More sharing options...
zomeizter Posted April 20, 2019 Share Posted April 20, 2019 23 hours ago, gogmorgo said: There are drain plugs in the floor pans already. Indeed, but them there plugs were a bit big and are not located on the lowest point... Link to comment Share on other sites More sharing options...
Vineyard86manch Posted May 5, 2019 Author Share Posted May 5, 2019 Update: After putting more RTV sealant around the windshield and sealing the antenna grommet as well, I waited for rain to see if that solved everything. I didn’t have to wait long and throughout today we have gotten about a half inch of rain. I went to look and I noticed it wasn’t as much leaked in as previous times but still a little water getting in. I snapped a pic, where under the dash would it be coming from? At this point it’s only leaking a little, I’m pondering just drilling a couple holes in the floor. Link to comment Share on other sites More sharing options...
