comanche89 Posted September 8, 2007 Share Posted September 8, 2007 how can i tell what kind of gears are in my axles Link to comment Share on other sites More sharing options...
DansGreyMj Posted September 8, 2007 Share Posted September 8, 2007 If you don't have tags on the diffs; put it in neutral, jack up the rear both tires off the ground and spin the driveshaft and however many turns of the driveshaft it takes to make the tire go around once thats what ratio you have. Link to comment Share on other sites More sharing options...
FxRacing282 Posted September 8, 2007 Share Posted September 8, 2007 or spin the tires until the driveshaft does a 360 turn. if it spins about 3 timres you have 3.07's if it spins 3 and a half times you have 3.56 if it spins about 4 times you have 4.10's Link to comment Share on other sites More sharing options...
Renegade Posted September 9, 2007 Share Posted September 9, 2007 Aw come on, it's SO much more fun to get all dirty removing a leaking dif cover & reading the numbers on the ring gear. Believe that & I'll tell you another one :D Link to comment Share on other sites More sharing options...
FxRacing282 Posted September 9, 2007 Share Posted September 9, 2007 renegade has a point. i like his idear Link to comment Share on other sites More sharing options...
Oizarod115 Posted September 9, 2007 Share Posted September 9, 2007 there are some basic sorta guidelines... not a rulebook mind you, but guidelines. 4.0+5spd=3.07 4.0+auto=3.55 2.5+5spd=4.10 and there were some funky ones in there too so don't be suprised if its not right but thats right probly a good 85% of the time and 94.65% of all statistics are made up on the spot ;) Link to comment Share on other sites More sharing options...
FxRacing282 Posted September 9, 2007 Share Posted September 9, 2007 haha :agree: Link to comment Share on other sites More sharing options...
comanche89 Posted September 9, 2007 Author Share Posted September 9, 2007 thanxs for all the help i will try em Link to comment Share on other sites More sharing options...
Geonovast Posted September 9, 2007 Share Posted September 9, 2007 I think it's more like.. 4.0 + 5spd = 3.07 4.0 + auto = 3.55 2.5 + stick = 3.55 2.5 + auto = 4.10 I have a 2.5 with a 4 spd and I have 3.55s Link to comment Share on other sites More sharing options...
Pete M Posted September 9, 2007 Share Posted September 9, 2007 One more try: 4.0 + stick = 3.07 4.0 + auto = 3.55 2.5 + 5spd stick = 4.10 2.5 + 4spd stick = 3.55 2.5 + auto = 4.56 2.8 = anyone's guess :D These are general rules of thumb. No guarantees. Link to comment Share on other sites More sharing options...
mfpdm Posted September 9, 2007 Share Posted September 9, 2007 If you don't have tags on the diffs; put it in neutral, jack up the rear both tires off the ground and spin the driveshaft and however many turns of the driveshaft it takes to make the tire go around once thats what ratio you have. I did the whole jack up and spin thing. I still don't know. I only got 2 turns to 1. :nuts: It's not the original axle and will be getting replaced anyhow but WTF? Link to comment Share on other sites More sharing options...
FxRacing282 Posted September 9, 2007 Share Posted September 9, 2007 and 94.65% of all statistics are made up on the spot ;) Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted September 9, 2007 Share Posted September 9, 2007 If you don't have tags on the diffs; put it in neutral, jack up the rear both tires off the ground and spin the driveshaft and however many turns of the driveshaft it takes to make the tire go around once thats what ratio you have. I did the whole jack up and spin thing. I still don't know. I only got 2 turns to 1. :nuts: It's not the original axle and will be getting replaced anyhow but WTF? If you turning it by the tires, you need to turn BOTH REAR tires at the same time or the spyder gears about half your numbers. Pop the cover and read the numbers stamped on the ring gear. Its fool proof!! CW Link to comment Share on other sites More sharing options...
Eagle Posted September 9, 2007 Share Posted September 9, 2007 I think it's more like.. 4.0 + 5spd = 3.07 4.0 + auto = 3.55 2.5 + stick = 3.55 2.5 + auto = 4.10 I have a 2.5 with a 4 spd and I have 3.55s The 2.5L with 4-speeds had 3.54 gears, but the 2.5L with 5-speed didn't. They generally (and in later years always) had 4.10s. 2.5L with automatic often had 3.73s in the early years. Chrysler standardized on 4.10s for all 2.5L XJs, but by then the MJ was history, and there were no more 4-speed manual tranny XJs being produced. Link to comment Share on other sites More sharing options...
Renegade Posted September 9, 2007 Share Posted September 9, 2007 Pop the cover and read the numbers stamped on the ring gear. Its fool proof!! Let me think....if I remember right, you divide the small number on the ring gear into the larger one (it'll read something like 3.549637blahblahblah. Basically 3.55) Link to comment Share on other sites More sharing options...
mjeff87 Posted September 10, 2007 Share Posted September 10, 2007 The numbers on the ring gear will look like this: (3.07 in this case) Jeff Image Not Found Link to comment Share on other sites More sharing options...
Pete M Posted September 10, 2007 Share Posted September 10, 2007 It's probably time to change the gear oil anyways, right? :D Link to comment Share on other sites More sharing options...
TNT Posted September 10, 2007 Share Posted September 10, 2007 One more try: 4.0 + stick = 3.07 4.0 + auto = 3.55 2.5 + 5spd stick = 4.10 2.5 + 4spd stick = 3.55 2.5 + auto = 4.56 2.8 = anyone's guess :D These are general rules of thumb. No guarantees. I have seen a 2.8 with 4.56, 4.10 3.73 and 3.55 gears stock... They are just anyones guess just like you stated. Link to comment Share on other sites More sharing options...
comanche89 Posted September 11, 2007 Author Share Posted September 11, 2007 what would happen if both axles have diffrent gears Link to comment Share on other sites More sharing options...
mjeff87 Posted September 11, 2007 Share Posted September 11, 2007 Short version........nothing, so long as you don't engage 4WD. If you do, the difference will cause bind in the transfer case, as both driveshafts will spin at different revolutions. End result will be a broken case, at the least. Link to comment Share on other sites More sharing options...
