Rear Shock length
Hey guys I searched and couldn't really find anything specific pertaining to this question.
I want to upgrade my shocks from the classic white body lift shocks that come on most aftermarket lift kits. As you can see in my sig, I did a soa rear lift with 2wd leaves. I was considering getting bilsteins but I don't know what lengthtravel shock to run the rear? 10", 12", or 14". I do plan in the future to add shackles or an add a leaf if that changes anything.
The main kit I have been looking at is Bilstein Gas Shock Set Jeep Cherokee XJ w/6-8" Lift
This kit comes with 12" travel 5100s up front and 12" travel 5125s for the rear. Any help is greatly appreciated
What are you using for mount points?
Ultimately you're going to need to measure them.  I'm using almost stock length shocks with my SOA, because I put XJ style shock mounts on the axle.  They're the longest I can run without having issues with them bottoming out before I'm on the bumpstops.  If you have really low mounts on your axle you may be able to run longer, or if you have more bumpstop than I do.
When you add a longer shackle or AAL it will absolutely change everything too.
Expand
You're looking at the wrong specification. You need to measure the distance from your lower shock mount to the upper shock mount, then choose a shock that will put that dimension approximately at the mid-point of the shock's travel.
^ What he said. Measure if you want to be certain.
Also, in stock form Cherokees and Comanches don't use the same length rear shocks. So when you look at a kit spec'd for a Cherokee with [X]" of lift, that doesn't mean it will fit a Comanche with the same amount of lift.
Expand
In fact, a Cherokee kit won't work for a Comanche.
When I removed the 4" lift from my '88 MJ Chief, I had a good set of XJ shocks I wanted to use. The fronts. of course, went right in. For the rear, I foolishly assumed that I could just remove the bar pins from the XJ shocks and bolt them into the MJ. So I removed the bar pins -- only to find that when fully extended the rear shocks were a half inch too short to go into the MJ. So I then had a perfectly good pair of shocks that didn't fit an MJ, and which could no longer be used in an XJ because I had removed the bar pins.
Not ... smart. Shock travel was immaterial, since they wouldn't even go into the vehicle.
Just so you guys get an idea of what my rear axle/ shock set up looks like.
When I head back home from school I will measure the distance from mounting point to mounting point and find shocks that would fit in there.
How would shackles/add-a-leaf affect the shocks. Would I have to get longer ones? I haven't been completely sold on either was just thinking about them
Expand
That looks pretty good, I'm impressed. Nice job.
My 5125 part number is - 33-186542
If your static measurement is 20" to 22" these will fit.
There are no MJ 'kits', spec your own shock, do your homework. Bilstein has a site and lists all their shocks with specs.
https://cart.bilsteinus.com/Portals/0/BILSTEIN-OR-Catalog-2019(WEB).pdf
I'm thinking of going 5165 next time around.
  On 3/26/2019 at 11:42 AM, 89eliminator said:
i had almost an identical setup (SOA, 2wd leafs, lift shackle) and the same shock mounts.  I ran 12" travel 5100s.  Had about 4-5" uptravel.
Expand
As I commented above, without knowing the compressed and extended length, travel length tells you nothing about whether or not a particular shock will fit. Here's a link to Monroe's fitment section on their web site. Notice how you can find shocks of similar length with greatly different travel, and you acn find shocks with similar travel but greatly different extended and/or compressed length. You can't just buy a shock based on travel distance without first knowing the distance between your upper and lower mounts.
http://www.monroe.com/downloads/install-instructions-guides/MonroeMountingLengthSpecifications.pdf
Swampy: Yes, a longer shackle or an AAL will change the distance between your shock mounts. It's a lift -- the reason you would do a shackle or an AAL is to get more lift, right? So if you intend to do one of those modifications, wait until you have made the suspension change and then buy your shocks to fit the modified suspension.
Expand
the 5100/5125 series only has one collapsed/extended length in the 12" travel category
Not sure how good these numbers are but I pulled them from rusty's offroad. These numbers are from their 6.5" Mj long travel kit and the rear shocks are
collapsed 17.58" and extended 29.57".
I don't have numbers for my specific comanche but it should be close as I am 5.5-6" of lift rear
Expand
But you have custom lower shock mounts, so you have no idea how those compare to any other Comanche with the same amount of lift.
You NEED to crawl under your truck and measure the distance between the upper and lower shock mounts when the vehicle is unloaded and parked on level ground.
Expand
  On 4/7/2019 at 2:57 AM, Swampy said:
the measure meant from mounting point to mounting point on my rear axle is 20". and with a 1" add a leaf or 1" shackle it would be in the 21-22" range
Expand
  On 4/9/2019 at 3:05 AM, Swampy said:
Maybe I could change my shocks mounts. I wanted to keep them up out of the way from getting hung up on different things, but if its an issue I can lengthen them below the axle
Expand
:confused:
Why not just buy shocks that are the right length for your suspension? That's why they make shocks in different lengths. You put the shock mounts where they are for a reason.
  On 4/9/2019 at 5:01 AM, Eagle said:
:confused:
Expand
 Was thinking out loud... some ideas are best not spoken lol. I will order some bump stops and shocks to help finalize the rear suspension
Has anyone suggested the bar pin eliminators yet? It only gives you 3/4 to an inch of extra travel,but making it easier to change your shocks(priceless).That also adds to  the type of shocks you can use.I also have a little trick I used on my XJ front shock mount,(top side).It should work on any MJ.If I can find them I'll post some pictures.
Expand
He asked about rear shocks. The XJ used bar pins on the upper end of the rear shocks, the MJ didn't. And his custom lower mounts don't. No bar pin eliminators needed.
