JeepSchmidt O'Guinness Posted March 17, 2019 Share Posted March 17, 2019 Does anybody know what year the ax-15 was actaully able to use gl-4 spec gear oil.... Or if they switched from brass synchro rings? Link to comment Share on other sites More sharing options...
PIKE Posted March 17, 2019 Share Posted March 17, 2019 I would recommend using Redline gear oil. They make transmission oil that does not have posi traction additives and also safe for ax-15 gear boxes. MTL is very popular and is what i use in my 1996 f350 powerstroke zf5 manual transmisssion. The gear oil of choice for heavy duty use. Sorry not to answer you original question. Link to comment Share on other sites More sharing options...
Eagle Posted March 18, 2019 Share Posted March 18, 2019 3 hours ago, JeepSchmidt O'Guinness said: Does anybody know what year the ax-15 was actaully able to use gl-4 spec gear oil.... Or if they switched from brass synchro rings? I wasn't aware that any year was okay with GL-4. The chart at my Jeep dealership's parts room shows 10W-30 motor oil for the AX-15. Link to comment Share on other sites More sharing options...
DirtyComanche Posted March 18, 2019 Share Posted March 18, 2019 9 minutes ago, Eagle said: I wasn't aware that any year was okay with GL-4. The chart at my Jeep dealership's parts room shows 10W-30 motor oil for the AX-15. Agreed. Nothing ever changed with the synchros. If you order new ones now (I have a brand new set in a box) they are the same as they ever were. Link to comment Share on other sites More sharing options...
Jeep Driver Posted March 18, 2019 Share Posted March 18, 2019 40 minutes ago, Eagle said: I wasn't aware that any year was okay with GL-4. The chart at my Jeep dealership's parts room shows 10W-30 motor oil for the AX-15. Yep. That's what I ran in my last AX5 and that is what is in my current AX5. I have no idea why this gear oil debate keeps coming up. Link to comment Share on other sites More sharing options...
Dzimm Posted March 18, 2019 Share Posted March 18, 2019 Yeah Redline MT90 or 10w-30. Only acceptable things for the AX-15 or AX-5. From what I've read and come across, there was an incorrect factory recommendation years ago that caused this to be an ongoing debate. Link to comment Share on other sites More sharing options...
JeepSchmidt O'Guinness Posted March 18, 2019 Author Share Posted March 18, 2019 Wasn't trying to beat that dead horse, just couldn't remember if the synchro ever changed material through out the ax-15's production. Thanks' All. Link to comment Share on other sites More sharing options...
