jdog Posted February 15, 2021 Author Share Posted February 15, 2021 A bit cold outside If your cold there cold, be sure to bring your truck inside well now that its inside, here's the list so we'll start in the rear and work our way forward old spring out new spring in repeated on the other side then its time to do the brake line I had to drill out the bracket opening, and i put a bushing on the axle side just to fill it in to fit the smaller bolt. next up is to extend the rod for the sensing valve Link to comment Share on other sites More sharing options...
jdog Posted February 17, 2021 Author Share Posted February 17, 2021 new u-bolts installed, rear bumper installed (no spoilers) Link to comment Share on other sites More sharing options...
jdog Posted February 28, 2021 Author Share Posted February 28, 2021 been a busy week, really had to bust butt after last weekend of not being able to work on Toph with that here is what has happened this week. I pulled the fuel tank to inspect, found a vent hose smashed from the factory cleaned the top, and replaced the hoses off the tank. reinstalled the tank note to the next person, drain the tank. Once the tank was installed i installed the skid plate for the fuel tank. re-installed the driveshaft(cause you gotta pull it to install the tank/shield). drain the rear diff, and changed out the gasket. did a fluid service on the transfer case and installed the skid plate. I performed hOrnbrod load valve rod. on to the front of the truck New upper,lower and springs. new track bar and tie rods, new brake lines. up next: front brakes/rotors/calipers, p/s pump and lines Link to comment Share on other sites More sharing options...
jdog Posted March 8, 2021 Author Share Posted March 8, 2021 tore out the interior worst rust on the floor, but it's just surface Three pedals next out was the dash Dash harness replacement front side of dash can't wait to get a radio from minuit, still deciding between the wood grain or a brushed silver bezel started on the sound deadning and speakers/amp. Next up heater core/box Link to comment Share on other sites More sharing options...
scaleless Posted March 8, 2021 Share Posted March 8, 2021 35 minutes ago, jdog said: Ah, I passed up a wood grain bezel at the scrapyard the other day and now you're making me regret it! Link to comment Share on other sites More sharing options...
jdog Posted March 8, 2021 Author Share Posted March 8, 2021 4 minutes ago, scaleless said: Ah, I passed up a wood grain bezel at the scrapyard the other day and now you're making me regret it! Woodgrain always looks good Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 8, 2021 Share Posted March 8, 2021 Gotta get the early Renix woodgrain from the waggys. Link to comment Share on other sites More sharing options...
jdog Posted March 8, 2021 Author Share Posted March 8, 2021 Will have to check the pile tomorrow and see if I have one, that may be the one I am missing Link to comment Share on other sites More sharing options...
jdog Posted March 15, 2021 Author Share Posted March 15, 2021 busy week, got the hvac box installed, dash re-installed, wired up, have a few wire gremlins but will get them figured out. sound proofing done. l/f brake caliper rebuilt, new brakes installed. I have to get another kit for the r/f and then install the brakes on that side. up to carpet in the interior but with snomageddon I couldn't set the carpet out to soften up. I'm still trying to decide which wheels to run, kinda particular to the cop rallies. Link to comment Share on other sites More sharing options...
jdog Posted March 22, 2021 Author Share Posted March 22, 2021 Disclaimer: if you decide to rebuild your calipers you are doing it at your own risk. I hold no responsibility if you screw up and crash. Been busy again, heater box got installed, next up was front shocks you all know how to install them and what they look like on the vehicle. Next was front brakes, when i disassembled the front end I found that the brakes were wearing uneven, I also had a pull at hard braking. Now is the time to do brakes since its all apart, inspect and found calipers are more $ then i want to spend, but the rebuild kits are less then 10$. Now I have rebuilt calipers before and have no issue doing it but figured id throw the disclaimer out there. First thing is remove the caliper next you have to get that piston out, easiest is to use air, put a block of wood in front of the piston and apply compressed air to the inlet, it will pop. Nasty, and to think thats the back side. you will want to clean it completly Much better Next up is the housing same thing you will want to get that all cleaned up. There is also a o-ring that goes in that second divot. once you have gotten high with the brake clean and everything is shiny, install the o-ring into the housing. then install the dust boot., its a lot easier if you have it in a vise. install your piston This will be the hardest part cause you need to get the edge of the boot onto the ring of the piston, I used a seal tool, basically a flat dull screw driver, be careful not to tear the boot. This is with the boot on the piston, next up is to press the piston down like you would in a normal brake change. then install back on the same side, if you pulled them both off and didn't mark them, the bleeder always goes to the top. installed with new rotors and pads. next up is carpet since sat is the warmest we've had or going to have for the next week. I really miss doing interior. carpet is all cut and molded in, just have panels to re-install. Link to comment Share on other sites More sharing options...
jdog Posted March 28, 2021 Author Share Posted March 28, 2021 slow weekend and doesn't seem like i did much but The brakes are bleed, dash was removed a few times and is now installed for good. part of the trim is on, steering column got installed. cassette player purchased for the shop. more wiring done. and booster swapped. oh yeah and one rear shock lol. this weeks plan is to wire the amp/speakers, finish the interior trim and install the seats. Link to comment Share on other sites More sharing options...
jdog Posted April 10, 2021 Author Share Posted April 10, 2021 other shock has been installed, weatherstripping installed, amp wired, seats installed, interior is finished. starting in the engine bay. Link to comment Share on other sites More sharing options...
jdog Posted April 19, 2021 Author Share Posted April 19, 2021 it's almost out of the garage (not finished cause jeeps are never finished) got the front bumper on. fogs bolted on ACOS installed need 1 a/c line and i can charge that system. serviced the front diff and also deleted the axle disconnect. rear wheels are on, still need to go get tires new radiator installed, a/c condensor new dryer new valve cover gasket and new vacuum harness cleaned the k&n ( if you have one and you haven't cleaned it you might want to check it) greased the front end new p/s lines installed interior is completed Link to comment Share on other sites More sharing options...
MiNi Beast Posted April 19, 2021 Share Posted April 19, 2021 good progress. I do dig the woodgrain. Link to comment Share on other sites More sharing options...
jdog Posted April 19, 2021 Author Share Posted April 19, 2021 11 minutes ago, MiNi Beast said: good progress. I do dig the woodgrain. Thank you, figured it was something different that I hadn't done yet Link to comment Share on other sites More sharing options...
MiNi Beast Posted April 19, 2021 Share Posted April 19, 2021 with 21 slots and some grain you got yourself one of them there fancy jeeps i reckon. Link to comment Share on other sites More sharing options...
jdog Posted April 19, 2021 Author Share Posted April 19, 2021 36 minutes ago, MiNi Beast said: with 21 slots and some grain you got yourself one of them there fancy jeeps i reckon. fancy, nah not me Link to comment Share on other sites More sharing options...
jdog Posted April 27, 2021 Author Share Posted April 27, 2021 welp suppose we are getting close to the end of the parts pile fog lights are wired, roll bar is bolted down, fluids filled. next up alignment and new windshield Link to comment Share on other sites More sharing options...
jdog Posted May 1, 2021 Author Share Posted May 1, 2021 drove it around today, had to adjust the rear prop valve, gave it a bath. before after Link to comment Share on other sites More sharing options...
Pete M Posted May 2, 2021 Share Posted May 2, 2021 lookin' like a Jeep now Link to comment Share on other sites More sharing options...
jdog Posted September 10, 2021 Author Share Posted September 10, 2021 Always check your spare Link to comment Share on other sites More sharing options...
MiNi Beast Posted September 10, 2021 Share Posted September 10, 2021 I always thought if you carried a spare you will end up using it. 🤔 Link to comment Share on other sites More sharing options...
jdog Posted September 11, 2021 Author Share Posted September 11, 2021 21 hours ago, MiNi Beast said: I always thought if you carried a spare you will end up using it. 🤔 unless its in the same shape as the troubled tire Link to comment Share on other sites More sharing options...
jdog Posted February 16, 2022 Author Share Posted February 16, 2022 A week late again but happy build day Toph Link to comment Share on other sites More sharing options...
Pete M Posted October 6, 2023 Share Posted October 6, 2023 you sold your truck!?! Link to comment Share on other sites More sharing options...
