jdog Posted August 30, 2019 Author Share Posted August 30, 2019 Roll bar is out. now time to install the bed light. Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 30, 2019 Share Posted August 30, 2019 52 minutes ago, jdog said: Roll bar is out. now time to install the bed light. Good luck! Link to comment Share on other sites More sharing options...
jdog Posted October 7, 2019 Author Share Posted October 7, 2019 Procrastinated the lca still, I did however remove and redo the headliner. While it was out the bedlight went in. I also removed the rocker bases and installed the old bases, some might enjoy ducking to get into the truck, not me I tried to give it time but just couldn't get used to it. Stock 1988 swb 4.0 ax15 np 231. Link to comment Share on other sites More sharing options...
jdog Posted October 14, 2019 Author Share Posted October 14, 2019 Greased the front end today, also swapped wheels with the xjStock 1988 swb 4.0 ax15 np 231. Link to comment Share on other sites More sharing options...
Pete M Posted October 16, 2019 Share Posted October 16, 2019 those wheels are awesome Link to comment Share on other sites More sharing options...
jdog Posted October 16, 2019 Author Share Posted October 16, 2019 There Mopar cop wheelsStock 1988 swb 4.0 ax15 np 231. Link to comment Share on other sites More sharing options...
jdog Posted November 9, 2019 Author Share Posted November 9, 2019 Shakes got worse which means I got off my lazy butt and took a look. I found that the tie rod sleeve nuts had loosened causing slop in the tie rod. Tightened and the bad shakes went away still have a slight shake every once in a while gonna replace the stabilizer soon as I'm not sure how old it is. Stock 1988 swb 4.0 ax15 np 231. Link to comment Share on other sites More sharing options...
jdog Posted January 8, 2020 Author Share Posted January 8, 2020 Tease Stock 1988 swb 4.0 ax15 np 231. Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 8, 2020 Share Posted January 8, 2020 Looking good Link to comment Share on other sites More sharing options...
fiatslug87 Posted January 8, 2020 Share Posted January 8, 2020 I like the '91 clock, always thought it looked better than the others since it matches the left side panel. Link to comment Share on other sites More sharing options...
jdog Posted January 8, 2020 Author Share Posted January 8, 2020 I like the '91 clock:L:, always thought it looked better than the others since it matches the left side panel. Me too, wiring wasn't bad eitherStock 1988 swb 4.0 ax15 np 231. Link to comment Share on other sites More sharing options...
jdog Posted January 9, 2020 Author Share Posted January 9, 2020 Looking good Thank you Stock 1988 swb 4.0 ax15 np 231. Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 9, 2020 Share Posted January 9, 2020 Did you get the tach dialed in? Link to comment Share on other sites More sharing options...
jdog Posted January 9, 2020 Author Share Posted January 9, 2020 By ear, haven't verified by scanner yet but I gotta pull it back out, the speedo doesn't operate correctly Stock 1988 swb 4.0 ax15 np 231. Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 9, 2020 Share Posted January 9, 2020 Yup. Tons of fun to do that to get it just right. Link to comment Share on other sites More sharing options...
jdog Posted January 19, 2020 Author Share Posted January 19, 2020 Welp I'm about 200 off on the tachas it sits now. It received a new steering stabilizer. I also removed the brush guard, now I will be on the hunt for chrome. Stock 1988 swb 4.0 ax15 np 231. Link to comment Share on other sites More sharing options...
jdog Posted February 17, 2020 Author Share Posted February 17, 2020 Welp got to work on it over the weekend. Reset and installed the other speedo I had, old one only worked til 45 mph, after that it bounced and spun around so bad. Fixed the oil pressure gauge and adjusted the tach. Changed the oil for the year and install the front skid plate. While it getting parts got to meet bucky and Bob. Got the bored throttle body installed and fixed the sensor ground, yet another cruiser tip finished, also removed extra wires from previous owners.No pictures just dreams. Stock 1988 swb 4.0 ax15 np 231. Link to comment Share on other sites More sharing options...
jdog Posted February 17, 2020 Author Share Posted February 17, 2020 Oh yea also missed posting happy build day, but I took it out and gave it a bath, hopefully it was happy. Stock 1988 swb 4.0 ax15 np 231. Link to comment Share on other sites More sharing options...
jdog Posted February 22, 2020 Author Share Posted February 22, 2020 UmStock 1988 swb 4.0 ax15 np 231. Link to comment Share on other sites More sharing options...
89 MJ Posted February 22, 2020 Share Posted February 22, 2020 What happened? Link to comment Share on other sites More sharing options...
jdog Posted February 22, 2020 Author Share Posted February 22, 2020 Found chrome pieces I was missingStock 1988 swb 4.0 ax15 np 231. Link to comment Share on other sites More sharing options...
jdog Posted February 22, 2020 Author Share Posted February 22, 2020 Also tow hooks, still unsure about the air dam. Will either replace or paint, this one's weird as it's opaque Stock 1988 swb 4.0 ax15 np 231. Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 23, 2020 Share Posted February 23, 2020 1 hour ago, jdog said: Also tow hooks, still unsure about the air dam. Will either replace or paint, this one's weird as it's opaque Stock 1988 swb 4.0 ax15 np 231. I got a spare one I bought off a member back in December. Its black too but doesn't have the holes cut for the tow hooks. Link to comment Share on other sites More sharing options...
jdog Posted February 23, 2020 Author Share Posted February 23, 2020 So now that I'm on the computer and not mobile, lets explain. It was a good day at the junkyard, found a decent chrome bumper and grill surrounds off of a xj, on another xj found the chrome tow hooks. installed after a little cleaning, also found and installed the chrome trim pieces behind the arm rests. forgot to grab the brackets for the tow hooks as i knew i had a set, will have to go back and see if this one had the brackets. Still deciding on chrome door handles, might just stick with the black ones as i am not looking to put everything chrome. Also next time i pull the bumper one of the corner guards is getting swapped, after installing the bumper realized the one has a split in it. Link to comment Share on other sites More sharing options...
jdog Posted February 23, 2020 Author Share Posted February 23, 2020 always nice seeing AMC badges on parts Link to comment Share on other sites More sharing options...
