  • Replies 205
Had several parts show up today. I have an edelbrock head and 97+ doors that I'll be installing on the truck over winter. I'm hoping to have this truck on the road and my DD by Springish.
Also, my brother works at a local shop, and I'll have them pull the original motor to be replaced with the stroker motor over winter. Hopefully that will save time.
On 8/13/2026 at 5:40 PM, 89 MJ said:
Glad to see this update!
Thank you! I had quite a bit going on. Unfortunately, the Comanche sat for a few years.
Finally mounted the Rubicon dana 44 front axle and moved the truck. I'll be working on my brakes next weekend.
Several parts started showing up as well. Hopefully I'll have more time over winter to install everything.
The negative: It rained this weekend. I knew there was a leak around the door seals, but it appears that the rear window seal has cracked. I'm hoping there isn't a lot of rust at the roof, but I can see heavy corrosion where the headliner Velcro's at the rear window.
